Water Pump Replacement - JeepForum.com
post #1 of 6 Old 07-12-2005, 06:19 PM Thread Starter
RedfireGTP
I have a 98 Jeep cherokee Sport 4.0L and my water pump went bad...does anyone know how to replace one....or a write up on it....Thanks in Advance...
LuLu
RedfireGTP is offline
post #2 of 6 Old 07-12-2005, 06:57 PM
Rock1127
I have a few friends named Haynes and Chilton who know--along with a million other things :P
Seriously, though, you should really pick up a Haynes or Chilton manual at your local Auto parts store. It will pay for itself in absolutely no time at all, and it isn't even expensive anyway.
I myself know nothing about replacing it, but i'm sure alot of the other members do and will reply soon. Good luck.
Rock1127 is offline
post #3 of 6 Old 07-13-2005, 07:32 AM
75SV1
This is a pretty easy job. You will need to take off the serpentine belt. and probably both the auxilarry fan and the main fan.Drain some of the coolant out. Unscrew the bolts holding on the water pump. Scrape the old gasket material off. put new gasket and water pump on. Torque the bolts. Replace the fans and serpentine belt. Put back in the coolant. If 87-90 burp the cooling system. You might think about replacing the thermostat and the coolant at this time. I'd get a Haynes or Chiltons to follow direction.
Tom
75SV1 is offline
post #4 of 6 Old 07-15-2005, 04:13 PM
jgoode3402
jgoode3402's Avatar
Tom
You make that sound easy. By the time I finished mine I was almost in tears from frustration (and hitting my knuckles trying to put that d=-=- fan back on).
That having been said, it can be done even by a novice like me. I would definitely go by an auto parts store and pick up a Haynes or Chilton's book and plan on working for a few hours.
Oh yeah, mine is an XJ which would account for the cramped space and knuckle banging...it might be easier with another model.
'97 XJ Country
3" Rusty's AAL w/BFG a/t 31x10.50
Stock wheels & BS
XM Radio
jgoode3402 is offline
post #5 of 6 Old 07-20-2005, 06:50 AM
75SV1
Actually, the Jeep is pretty easy to work on comparatively. Usually the scraped knuckles come from bolts that have been assembled for a while. They somewhat corrode together and are harder to loosen. The clutch fan presents problems for some, as it spins when you try to loosen the bolts. I use a long screw driver and put it between two of the bolts to stop the rotation. THen loosen on of the other bolts. I keep all the bolts in there till I loosen all of them.
Believe me, the 4.0 in at least the Cherokee and Comanche have some room around the parts as compared to a lot if not most cars. Pop the hood on a newer Honda. I don't even see how air flows around those engines.
Tom
75SV1 is offline
post #6 of 6 Old 07-25-2005, 10:52 PM
TXjeepTJ
TXjeepTJ's Avatar
ive replaced my water pump 2 times ... 1st time was a lil bit frustrating.. 2nd time was a breeeeeze
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
4.0L Oil Pump question and Water Pump frhrwa Engines & Drivetrain 2 05-28-2009 02:50 PM
water pump Krazee Engines & Drivetrain 1 01-20-2007 06:24 AM
1995 GC Laredo Water Pump Replacement Brian's 97 ZJ Engines & Drivetrain 4 09-05-2006 10:49 AM
water pump Khriscom Engines & Drivetrain 1 12-14-2003 10:50 AM
AMC 360 water pump ???s slickwillie Engines & Drivetrain 4 11-22-2003 08:52 AM
