I recently built my own oil pan skid and I built a brace that went between the frame to support the pan. the brace had a "notch" for the drive shaft to have room to move up and down. Well I miss judged the space and under hard breaking the driveshaft would rub on the brace. After about 2 days I was able to chop off the piece. But now I have vibes over 50mph. My question is how can i get rid of those vibes. I did not have them before with 2inch of lift. I am figuring I hit the shaft hard enough to slightly move the transfer case out of allignment? if you loosen the bolts on the transfer case slightly.... drive around and tighten them back up will it re-align them? or am i thinking wrong here?
thanks for the help
thanks for the help
