Vibration After Rear Main Seal Replacment - JeepForum.com
post #1 of 4 Old 07-07-2005, 06:55 PM Thread Starter
waterfowlhntr
My 93 YJ was leaking oil. After looking into the YJ threads I found out how easy it is to replace the rear main seal. On Saturday I went for it, and found it pretty easy. After the replacement I drove about 5 miles and noticed a vibration I never felt before. It will happen in or out of gear, and is really noticable at 2000rpm. What did I screw up. I have already taken it back apart to make sure everthing was tight. I have it on the ramps right now prep. to get into it again to check the bearing cap itself. Any feedback would be appreciated.
waterfowlhntr is offline
post #2 of 4 Old 07-16-2005, 09:46 PM
Traveller
Did you mark your clutch or torque converter before disassembly? If either of these were bolted back together in a different position than original it could affect the balance.
Traveller is offline
post #3 of 4 Old 07-17-2005, 08:09 AM
diesel158
Is it standard or auto?
leave the gun,take the canoli's
diesel158 is offline
post #4 of 4 Old 07-17-2005, 08:32 AM
diesel158
It's on ramps,so you went through the pan,if you did there's a chance you nicked the bearing.
Not the rear main seal al666 Engines & Drivetrain 11 03-05-2007 06:00 PM
rear main seal whitezombie Engines & Drivetrain 2 02-16-2007 04:30 PM
rear main seal? Johnny World Engines & Drivetrain 3 05-21-2006 04:11 PM
rear main seal 4.2 88Blackwrangler Engines & Drivetrain 1 03-17-2005 05:02 PM
Rear Main Oil Seal compfreak2002 Engines & Drivetrain 5 06-28-2002 03:44 PM
