Used dana 35 question - Page 2 - JeepForum.com
post #16 of 27 Old 01-13-2014, 09:43 AM
Evildriver-3
Originally Posted by joeydominick View Post
I you guys think there's a big difference in say a 99 dana 35 3.07 with 112000 on and a 98 same axle with 70000 miles on. The first one is 200 the second is 500
What is wrong with yours ? If it;s more than spiders or A axle then get the $200 priced, but remember when you buy someone elses junk you're getting someone elses junk.
If all you need is A axle or spiders than you're far better off fixing yours, and it'll be cheaper
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #17 of 27 Old 01-13-2014, 10:03 AM Thread Starter
joeydominick
No one around here will touch it
joeydominick is offline
post #18 of 27 Old 01-13-2014, 10:03 AM Thread Starter
joeydominick
Gears and pinions shot
post #19 of 27 Old 01-13-2014, 10:06 AM
justanotherjpr
Assuming both are in good shape, I'd buy the cheaper one. Pull the cover, check the gears, make sure everything is in good shape. The pinion should not have any side to side or in and out movement. A little rotational play is OK.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #20 of 27 Old 01-13-2014, 11:05 AM
Evildriver-3
If you need a R&P then either of those 35's are cheaper
]=Supershafts=[
post #21 of 27 Old 01-14-2014, 05:21 PM Thread Starter
joeydominick
Just got a response from daviesjeep, the have a set of dana 35 with 4.10 for 750. I have a stupid question for everyone, if I go with a set, is it an easy install ( I'm assuming and hoping just a bolt in? Thanks
post #22 of 27 Old 01-14-2014, 10:04 PM
Evildriver-3
It's work, you have brake lines to deal with and can break and make more work otherwise it's not a killer job
]=Supershafts=[
post #23 of 27 Old 01-15-2014, 03:52 AM Thread Starter
joeydominick
But still a basic bolt in on both front and rear, right?
post #24 of 27 Old 01-15-2014, 11:38 AM
Evildriver-3
Yes it's not any fabrication issues, the worst will be if the lines break, but you could avoid that by pulling the backing plates from the housing and not disturb the brake lines at all and then bolt them back onto the other axle.
I would do it that way then gamble the lines twist in the brake fitting.
]=Supershafts=[
post #25 of 27 Old 01-15-2014, 02:36 PM Thread Starter
joeydominick
Ok so my options that I've come across, I found someone that we rebuild with all new insides for 970, or take a trip to Ohio for a dana 30 and 35 with 4.10 gearing for about 1000 and my local will install for 400. Also I found a place 30 min away with dana 30 and 35 4.10 gearing but he won't open them up for me to check insides. He only wanted 500 for the set
post #26 of 27 Old 01-15-2014, 05:14 PM
Evildriver-3
Rebuild with a new carrier for 970 or R&P and spider assm and bearings ?
]=Supershafts=[
post #27 of 27 Old 01-15-2014, 05:17 PM Thread Starter
joeydominick
Same carrier with all new guts,
