uphill stall? - JeepForum.com
post #1 of 3 Old 02-11-2002, 09:42 AM Thread Starter
mike mcgovern
uphill stall?
i have an 82 cj-5 and recently had someone rebuild the carb, now everytime i try to climb the smallest hill, the jeep loads up and stalls, it has no problem going down anyting or even if i back up a hill, but if the nose is higher than the tail, it dies. Does anyone know what might be causing this, a stuck or cracked float maybe. Also its been having a hard time running at higher speeds,while its in 3rd or 4th and i try to accelerate hard, the jeep just blubers and doesnt accelerate. Why is this, any suggestions would be helpfull. Thanks
mike mcgovern is offline
post #2 of 3 Old 02-11-2002, 04:52 PM
Bob K
Bob K's Avatar
Almost positive that the float is not adjusted properly. The level is too high causing flooding on the slightest gragdation.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #3 of 3 Old 02-12-2002, 12:43 AM
89 YJ
I had same problem with mine. The fix it to adjust floats. I believe the book says quarter inch below for the floats, however, this is terrible setting if you offroad steep hills. I set mine at a little over 3/8s below and it help tons. Might be able to do a hair more, but I was worried about starving it at high speeds wide open. It has no prolonged wide open throttle problems where it is now.
89 YJ Islander, AC,PS, 10 inch lift, 32 BFG MT's, sway quick disconnect, rear track bar quick disconnect, 400 watt 12 speaker cd player for tunes,8000lb warn 8274 with 150 ft cable, and a high lift jack.. Lockers, 35's, webber carb and jacobs ignition comming soon.
89 YJ is offline
95 yj with no uphill power silverslider Engines & Drivetrain 5 11-24-2009 08:57 PM
Sputtering or wanting to stall? JEEPBURGH Engines & Drivetrain 1 10-28-2009 08:48 PM
Uphill Battle NIN20 General Jeep & Off-Road Equipment 2 03-27-2009 08:33 PM
stall on steep incline? brinoff General Jeep & Off-Road Equipment 7 07-28-2007 10:37 PM
