unusualy high idle rpm - JeepForum.com
post #1 of 9 Old 04-14-2002, 10:49 PM Thread Starter
Rudy
Some times when I start my 89 Cherokee 4.0 the engine will rev up to around 3000 rpm and wont come down unless I shut down the car and restart it. In some cases I have had to turn off the car and start it a couple of times to get the idle down. This also sometimes happens while the car is running, meaning The car starts just fine then I will notice while at a light or something that the idle is up to high, around 3000 rpm.
If any knows what is going on here or has experienced the same thing, a cure for this problem would be appreciated. Thanks
5.9 litre, stock. 89 XJ with 5 inch lift, roof rack and 31X10.5`s on 589`s. 76 Wagoneer with 401,edelbrock,MSD,Header and B&M auto shifter.
Rudy is offline
post #2 of 9 Old 04-14-2002, 10:56 PM
BlazinYellowTJ
my friend has an 87 with the same problem...idles high when first started, but comes down after he drives it for a while. i wonder if there is a connection? hmmm
2002 Yellow Tj
4" Procomp susp. lift
33x12.50x15 Mud Terrains
Line-x sprayed interior
J.E.E.P. = Just Empty Every Pocket
BlazinYellowTJ is offline
post #3 of 9 Old 04-14-2002, 11:00 PM Thread Starter
Rudy
If you find out any more on this problem from your friend I sure would like to know how to fix it.
Thanks, now I dont feel so all alone.
Rudy is offline
post #4 of 9 Old 04-14-2002, 11:31 PM
Drunc
Drunc's Avatar
are you sure the choke just isn't sticking??
make sure the petals and lnes aren't catching on anything
Jeep: '88 YJ Laredo I6, Kenwood Deck, Amp and 6x9's, 10" pioneer sub, 2.5" Skyjacker Kit with a 1" body and new front shackles, 32" Mud Kings on 8" Desert Crawlers, CJ style replacement mirrors, ditched the trackbars and the endcaps
Drunc is offline
post #5 of 9 Old 04-15-2002, 12:52 AM Thread Starter
Rudy
Where would I find the choke on my fuel injected 4.0?
Rudy is offline
post #6 of 9 Old 04-22-2002, 04:04 PM
jg
I have had the same problem with my 1990 4.0L Comanche. Changing the EGR valve reduced the problem alot, but it still happens occasionally, especially when I put low grade fuel into it - it really appreciates a tank of premium, although mid-grade works fine too.
It is most likely an issue connected with vacuum lines and/or emmission control components. Let us know what you come up with - this is a VERY common problem.
jg is offline
post #7 of 9 Old 04-23-2002, 02:12 AM
MonsterJ20
I had a motor with a bad tempature sensor that sent the idle up to over 3000 rpm. It took three different mechanics to figure out what was wrong. I can't promise it'll fix your problem but it fixed mine.
MonsterJ20 is offline
post #8 of 9 Old 04-23-2002, 12:47 PM Thread Starter
Rudy
Thanks for all the feed back, I`m going to try the temp sensor. I think the only way to change the egr valve is to replace the entire valve cover.
Rudy is offline
post #9 of 9 Old 04-29-2002, 10:13 PM
I-4
I-4's Avatar
i learned about this sensor bs the hard way.i wouldn't just go replacing sensors on someones advice.it get's rather expensive if it's not the fix.it sounds like a throttle position sensor...but don't take my word for it. spend the money and have a diagnostic done.it will save much heartache and money.btw, the 4 cylinder uses the same tps as the 4.0.it is a problem child.
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline
98 2.5L high idle jeepfreq Engines & Drivetrain 3 10-23-2009 03:07 AM
VERY High Idle GIJOEL Engines & Drivetrain 2 01-27-2009 05:18 PM
High Idle puddy Cheap Tricks & Fixes 1 06-08-2006 05:10 PM
88 4.0 High Idle eastslip Engines & Drivetrain 2 11-19-2005 03:06 PM
High Idle Mwrangler29 Engines & Drivetrain 3 02-19-2002 06:25 PM
