Unknown Metal Rubbing Sound Under Shifter - JeepForum.com
post #1 of 2 Old 10-24-2011, 06:03 PM Thread Starter
BayRunner
Hi all. Posted this in the WJ forum but got no replies, so hopefully some success here.
Transmission was rebuilt at the local shop. Afterwards, a odd metal rubbing sound appeared coming from somewhere under the shifter. It sounds like it is a rubbing sound caused by at least one surface rotating. Sound occurs only on braking and when I hit a large bump.
Shop thought it might be front driveshaft. They refurbed it. Sound remained. They pull the front driveshaft again and drove it around and no sound. They think the sound may be amplified by the driveshaft, but I am a bit uncertain because there is no hint of a problem with the shaft off.
Any suggestions/thoughts?
Thanks
Kevin
BayRunner is offline
post #2 of 2 Old 10-24-2011, 10:01 PM
jnicewan
I had one idea at first but if they had the driveshaft out it probably isn't my idea. Check the trans and engine mounts. I had bad mounts and it caused the front driveshaft to contact the skid plate/cross member when hitting bumps or backing up. It may be hard to do but start looking at everything that moves when rolling, and see how close they are to other objects, then look for signs of contact or rubbing.
jnicewan is offline
brackets, tubing or metal insert fill gap b/t bumper and metal so lamps dont shake osd Fabrication Shop 4 06-13-2010 02:40 PM
'05 TJ - Having wierd sound + possible parts rubbing together tiburonimbus Engines & Drivetrain 1 05-04-2009 09:04 PM
Rust due to metal on metal beeper General Jeep & Off-Road Equipment 5 04-15-2009 11:24 AM
unknown mud? 97wranglerkc General Jeep & Off-Road Equipment 4 01-24-2006 05:11 PM
Loud Metal Breaking Sound from Rear DrunkPenguin General Jeep & Off-Road Equipment 18 06-26-2005 01:55 PM
