Under-Hood Cloth - JeepForum.com
post #1 of 8 Old 05-09-2004, 02:54 AM Thread Starter
prossett
prossett's Avatar
Location: The oasis city of Al Ain, where the red sand dunes of the UAE meet the craggy mountains of Oman
Under-Hood Cloth
In order to put in hood vents, I'm thinking of removing the heat-resistant cloth thing that covers the underside of the hood.
What is that for and is there any benefit/danger to removing it?
I live in an extremely hot and dry sandy desert climate, and I want the vents to help get the hot air away from the engine.
International Jeep Club, Member No. 1 - Canadian living in the United Arab Emirates
White Jeep Club Member 33
prossett is offline
post #2 of 8 Old 05-09-2004, 05:16 PM
CJ-5
Cloth
The cloth is mostly there to reduce engine noise, it acts like a damper. Also keeps alot of heat off of the underside of the hood and saves the paint from fading so quickly. Louver your hood if you like, but leave as much cloth in tact as you can.
CJ-5 is offline
post #3 of 8 Old 05-09-2004, 11:48 PM
Dembones
Dembones's Avatar
Did YJs have that? My '94 doesn't...
Blue '94 Wrangler, 2.5L: Under monsterization
37" Claws/teralow/HPD44/Trussed HI9/5:38s/detroits/SOA, shackle reversal on rebuilt waggy and XJ springs.
Blue Jeep Club member 2
Dembones is offline
post #4 of 8 Old 05-10-2004, 04:23 AM Thread Starter
prossett
prossett's Avatar
Thanks CJ-5, I'll follow your advice. Yes, my 93 YJ Renegade has the underhood damper cloth. There are little plastic hooks that hold it on around the edges so you could look for those to see if your Jeep had it removed.
prossett is offline
post #5 of 8 Old 05-10-2004, 10:38 AM
Nymisus
Nymisus's Avatar
my 95 doesn't have the cloth or clips under my hood....let us know how the vents go I have been thinking about something like that for a while.....how do you plan on cutting them??
'95 jeep yj, first one and loving it
Herculined, rock it air intake, tb spacer, warn heavy duty front bumper with D rings and 2 KC 150watt Daylighters, warn rear bumper with tire carrier, 1" BL and 1" MML, 4"RE suspension w/dicos sitting on 33x12.5 swamper TSLs on rockcrawler
Nymisus is offline
post #6 of 8 Old 05-10-2004, 11:00 AM Thread Starter
prossett
prossett's Avatar
Well, I was inspired right here on Jeepforum (http://www.jeepforum.com/forum/f12/modified-hood-82282/ - nice pics!) but was thinking about trying to lower the temperature in the engine area for some time. It's getting real hot... though there's no signs of overheating
I was thinking I'd drill a couple of holes flush to the pattern and then saw through the sheet metal; shouldn't be too hard.
prossett is offline
post #7 of 8 Old 05-10-2004, 11:32 AM
MSHarnett
Broke Bogger
MSHarnett's Avatar
I put hood vents in my hood too. They are the from an old LeBaron Turbo. They look really cool and you can see the heat just flowing out like waves in the ocean.
Anyway, I may be worng, but I remember reading somewhere that those cloths are actaully fire blankets. In case of an engine fire they are designed to fall (the plastic mounts melt off) and smothers the fire.
As people said earlier, its also help despearse heat under the hood and prevent premature paint wear. It'll be no big deal removing it, and if you feel uncomfortable about it, just cut holes through it big enough for the vents.
Matt
MSHarnett is offline
post #8 of 8 Old 05-10-2004, 11:56 AM
jfw432
jfw432's Avatar
I'd be real quick to ditch mine if the hood itself wouldn't need a thorough cleaning afterwards. The cloth has got lots of oil on it from previous leaks and the hood has a nice dirt+oil film all over it so I'm waiting until I've got some time to play with it.
91 Cherokee with selectrac, 2" Rusty's AAL BB, 31x10.5 Liberator AT's
jfw432 is offline
What do you think it would run just to have the hood done? MusicMaverick General Jeep & Off-Road Equipment 6 12-29-2007 01:41 PM
Need an XJ hood Air Dog General Jeep & Off-Road Equipment 5 12-10-2007 03:44 PM
Hood Pin wenkebach Audio, CB & Ham Radios, GPS, & Electrical 4 08-04-2007 10:10 PM
fan in hood lrsmithwhaley Engines & Drivetrain 3 07-24-2006 10:06 PM
Fiberglass cloth strength? Kajunjeepn Fabrication Shop 17 04-25-2006 01:46 PM
