U-Joints axles to CV axles - JeepForum.com
post #1 of 1 Old 09-26-2012, 09:57 PM Thread Starter
nogenius99r
It can be done! Swapped out U-Joint axles from 99 Cherokee for CV joints from 98 Grand Cherokee. The spindles are all 27splines, it doesn't matter if its full time or part time in the parts description. All that matters is the length. The left one has to be 23 inches long and the right one has to be 38 1/2 inches. The outer ends can be a little longer, about 1/2 inch. They will still fit over wheel. No wabble on turns, very smooth in every direction and 4 wheel drive transition was very smooth. No more pounding out old U-Joints from their axles.
nogenius99r is offline
Swapping out u-joints for cv axles nogenius99r Engines & Drivetrain 4 09-14-2012 12:44 PM
RCV Axles surfdogdude Engines & Drivetrain 0 10-12-2011 08:36 AM
F-350 Axles jeepthing360 Engines & Drivetrain 2 10-11-2011 01:14 PM
8.8 and axles ? 98flstf Engines & Drivetrain 1 01-31-2010 04:22 PM
39s on what axles?.... white_elephant General Jeep & Off-Road Equipment 35 09-13-2007 07:23 AM
