U-Joint U-Bolts? - JeepForum.com
post #1 of 2 Old 03-24-2007, 08:49 PM Thread Starter
witsmok
U-Joint U-Bolts?
I broke a strap bolt on my rear u-joint ('93 YJ) today on the trail. Luckily I was able to remove the broken bolt and 2 hrs later (Trip to the parts store) we were back on the trail.
I now want to upgrade the weak strap/bolt combo with u-bolts. My understanding is that by drilling out the bolt hole in the pinion yoke u-bolts can be used and are much stronger.
Where do you buy the correct u-bolts for use on the rear u-joint (Dana 35).
Thanks in advance.
93 YJ 4.0L HO
3.5" Suspension Lift 2" Shackles, 33x13.50 SS LTB 15x10 Black Rock Crawler Rims, 8K LB Winch, and other "Required" upgrades
Green Jeep Club Member #158
99 WJ My Wife's Grocery Getter
witsmok is offline
post #2 of 2 Old 03-24-2007, 09:43 PM
Kerndone
I lack money
Kerndone's Avatar
I don't believe it is that easy. I don't think there is enough clearance on the back side of the yoke for the nuts to secure the u-bolt. However, if you can just drill out the yoke on the YJs, then you can get a u-bolt kit from any auto parts store in the "help" section. Its u-joint specific rather than axle specific.
Red Jeep Club Member 111
'99 TJ - work in progress...see profile
'08 WK - Silver RME, DD.
Kerndone is offline
Butt Joint vs Mitered Joint ...Please help a newB dwilliamsceg Fabrication Shop 11 11-24-2009 07:00 AM
1986 U joint U bolts Gasket Engines & Drivetrain 0 02-20-2008 12:51 PM
u-joint retaining straps and bolts (where to find) JeepMKcomin Engines & Drivetrain 2 08-06-2007 02:05 PM
Hot U-Joint Loser1 Engines & Drivetrain 3 09-05-2006 05:07 PM
D-35 U-joint machoman Engines & Drivetrain 7 08-31-2006 06:15 AM
