u-joint size for front axle - JeepForum.com
post #1 of 17 Old 07-03-2007, 07:30 AM Thread Starter
nyoffroad
Ok so I have posted about a noise I have been getting from my front end for the last week. After talking to a friend of mine he is almost positive its a u-joint. So my question is what size u-joints do I need for the ends of the front axle? Thanks ahead of time for the help guys
3"Blackdiamond susp. lift
basic skid plates
Bushwacker brush and rocker guards
Rock-it air intake
more to come in future
nyoffroad is offline
post #2 of 17 Old 07-03-2007, 08:50 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I see you have a TJ based on your prior posts.
If it still has the stock D30 front axle, you need a Spicer 760-x u-joint. This replaced the old part # 297-x.
Wheelin98TJ is offline
post #3 of 17 Old 07-03-2007, 08:53 AM Thread Starter
nyoffroad
thanks and sorry I forgot to mention I have a tj, I guess that info would have helped a little bit
basic skid plates
Rock-it air intake
post #4 of 17 Old 07-03-2007, 09:36 AM Thread Starter
nyoffroad
ok so I just called Napa advanced auto and autozone, none of them have the spicer 760 u joint. So is the spicer just a better brand or something?
basic skid plates
Rock-it air intake
post #5 of 17 Old 07-03-2007, 09:44 AM
Wheelin98TJ
JEEP FREAK
Dana Spicer is the OEM part.
Napa used to sell them but I guess they no longer do.
post #6 of 17 Old 07-03-2007, 10:13 AM
chutta
Just bought a spare for my '05x(d30) and it was a Precision(napa)
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline
post #7 of 17 Old 07-03-2007, 10:27 AM Thread Starter
nyoffroad
Ok I think the guy at advanced auto said the u joint was a brute something. Just one more question are these a pain to change out yourself?
basic skid plates
Rock-it air intake
post #8 of 17 Old 07-03-2007, 11:09 AM
Wheelin98TJ
JEEP FREAK
Its a pretty easy job.
Here's a write-up that should help:
http://www.stu-offroad.com/axle/ujoint1/u-joint-1.htm
post #9 of 17 Old 07-03-2007, 12:12 PM Thread Starter
nyoffroad
So when the u joint comes off its going to be attached to part of my axle shaft?
basic skid plates
Rock-it air intake
post #10 of 17 Old 07-03-2007, 12:24 PM
ajmorell
ajmorell's Avatar
no vise versa, when your axle shaft comes off your u-joint is going to be a part of it.
ajmorell is offline
post #11 of 17 Old 07-06-2007, 03:44 PM
Trombino
Trombino's Avatar
1978 CJ7
We just installed a set of Brute U-Joints on my father-in-law's XJ this weekend. Toughest part was getting the hub unit off, but that was due to the large amounts of rust we were dealing with from the NY winters. After that, the job was probably around 45 min, including installing the new U-Joint and re-assembling. We used Stu's Write-up and it was extremely helpful. The only thing you will definitely need is a 36MM socket, and we also used a 3-tooth puller. However, a deadblow hammer would also have probably gotten the job done eventually.
'78 CJ7 -- Chevy 350 SBC, Holley 4-BBL, TH700R4, B&M Performance Shifter, Dana 300 w/ Twin Sticks, 3" Shackle Lift, 3" Body Lift, D30 Front (Disc), AMC 20 Rear w/ Moser 1-Piece, 4.10's, 35x12.50/15 General Grabber MT's, Cragar Soft 8's (15x8 w/ 4" BS)
Trombino is offline
post #12 of 17 Old 07-08-2007, 08:13 AM Thread Starter
nyoffroad
Yeah the damn hub assembly took me and my dad a good hour alone, but the good news is when I took the hub assembly off there wasnt a back to it anymore. Yeah all the bearings well the ones that were left were exposed. So it didnt end up being my u-joint instead it was my hub assembly so that made the job a little shorter(thats the good news). But a little more expensive then expected. And if you live in the rust belt and you have to remove a hub assembly you NEED a slide hammer they are a god send. Thanks again guys for all the help and suggestions
basic skid plates
Rock-it air intake
post #13 of 17 Old 07-08-2007, 11:24 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Brute is a store brand, I personally would look harder to find the Spicer 5-760X which is a very high quality, well sealed, durable u-joint.
Jerry Bransford is offline
post #14 of 17 Old 07-08-2007, 07:11 PM
Hydro
Hydro's Avatar
I plan on buying some Spicers shortly for my entire drivetrain.
you can find them at www.4wd.com and maybe some other sites
-Mike
tout le monde, tout mes amis, Je vous aime, Je dois partir. These are the last words I'll ever speak and they'll set me free.
Officially driving the Jason Ellis Bandwagon
Hydro is offline
post #15 of 17 Old 07-08-2007, 08:10 PM
blynyrd
blynyrd's Avatar
1976 CJ5
Napa can still get them , usually overnight, but most stores no longer keep them in stock, since there are too many people looking for something cheaper.
1976 cj5
mildly built 304, t150,d20 , open d30 front, arb'd 30 spline d44 rear, 4.10:1's, soa w/ mil. wrap springs and add a leaf's (leaves?) 35" pro comp mt's, mm se9500# winch (with the wicked cool wireless remote), and too many other custom touches to list.
I friggin hate purple
blynyrd is offline
U-joint size. Mud_Pig Engines & Drivetrain 1 03-17-2009 10:52 AM
Rubicon Front Axle U-joint binski Engines & Drivetrain 4 10-09-2007 12:19 PM
Rubicon Front Axleshaft U-joint Size and Want Your Opinion 97MeanGreenTJ Engines & Drivetrain 6 02-01-2007 04:56 PM
8.8 yoke joint size jipjip Engines & Drivetrain 7 08-19-2006 11:28 AM
New U-Joint Knuckles On front Axle Of 1994 YJ Jeepfreak81 Fabrication Shop 4 12-01-2002 12:20 AM
