U joint. Internal vs external retention - JeepForum.com
post #1 of 2 Old 07-06-2012, 02:34 AM Thread Starter
1995_XJ
1995 XJ Cherokee
Well I'm replacing u joints on my 1995 xj. I went to two different napas and got two different ones. They are both precision brand super strength. One is part number 280 and the other is 378. The 378 came with the normal c clips. When i opened the other one they looked weird. Kind of like a bubble letter c. I looked all around with a google search and couldn't find too much.
Now, here's where I get confused. I don't really know how the internal?(part number 280) clip goes on and works. I also don't know if each type is determined by the yoke, or f I can use either one.
If it matters I don't have abs, ( guy at napa asked don't know of it matters)
Sorry if I'm not clear on what I'm asking. Been searching for awhile and a little frustrated, I just want my u joints in!
Any help appreciated, here's some pics
Part number 280:
Part number 378:
1995 Cherokee Sport
1995_XJ is offline
post #2 of 2 Old 07-06-2012, 07:22 AM
KingtheZJ
internal c clips are for the axle shafts. external are for the drivshafts.
top pic is external, bottom pic is internal
internal go around the groove on the bottom of the cap. you will see when you dissasemble your current ujoints
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
u joint
Amp install + retention of factory amp?? mrbobian Audio, CB & Ham Radios, GPS, & Electrical 11 09-01-2013 07:49 AM
AX15 internal to external throw out bearing swap medictanker Engines & Drivetrain 4 04-30-2011 09:39 AM
going from internal to external slave on an ax5? yj_beater51 Engines & Drivetrain 2 09-03-2010 03:57 PM
Internal vs. External Winch Solenoid? Which is Better? CherryCj7 General Jeep & Off-Road Equipment 8 03-22-2010 11:19 AM
Butt Joint vs Mitered Joint ...Please help a newB dwilliamsceg Fabrication Shop 11 11-24-2009 07:00 AM
