Is a Truetrac worth installing over the factory LSD? (JK D44) - JeepForum.com
post #1 of 7 Old 05-03-2012, 03:57 PM Thread Starter
09YellowJK
2009 JK Wrangler
As much as I'd like to install an ARB setup in the rear of my JK, I can not afford the $1200 investment right now. I became more interested in the Eaton Elocker, but the research I keep uncovering is they aren't as strong in the D44 setup due to the unique "2 pinion" design, vs the 4 pinion design of the ARB or even the ELocker design of the D30/35. I've read that Eaton is working to fix this design issue, but no where have I read it is fixed or released yet.
SO this brings me to the Truetrac LSD. Is it so much better than the OEM LSD that came in my X? Are both these considered automatic lockers?
2014 JKU Rubicon - In the planning phase
'09 Wrangler "X"(SOLD)-4" Rough Country Lift, 35" Falken All Terrains, 4.88s, D30 w/Aussie Locker Sleeved/Gusseted, D44 w/Detroit TT
09YellowJK is offline
post #2 of 7 Old 05-03-2012, 04:08 PM
Technohead
In a word, YES.
The Tru-Trac is far superior to any other limited slip on the market. Personally, I recommend them for front axle applications, especially if you drive in the snow.
Buying the differential is only part of the investment. Gear setup is not cheap so if you plan to do any real wheeling then I strongly recommend holding out for a locker.
I have friends running Eaton e-lockers who beat the crap out of them with zero problems. Can't say the same for ARB's. Mechanicals are fine but half a dozen times a season somebody springs a leak in the air lines.
P.S. Neither the Tru-Trac or the factory LS is an automatic locker. In fact they are not even lockers. An automatic locker is one that locks (for real) automatically by internal mechanical action (no air, magnets, etc). For example, the Detroit Locker is an automatic locker. You might take a look at one of those. Nothing but bulletproof goodness.
-Eric
Technohead is offline
post #3 of 7 Old 05-03-2012, 05:40 PM
stokerdog
There are some times when only a locker will do. These times are rare unless you are one of the guys who only rides on trails with the warning "roll over and body damage likley!" I have replaced 5 OE slippers with TT's. 3 in Jeeps and 2 in 3/4 ton P/U's. I have never regretted it and have always liked the performance of a TT on road and off. Great mod for the rear of a DD.
"If a law is stupid, you have to break it."
HST
stokerdog is offline
post #4 of 7 Old 05-03-2012, 05:52 PM
BlueRubiconrich
The factory Tracloc is junk ,A powerloc is better, but it has clutchs to and will some day need a refresh. A tru trac has ramped gears and is a great L/S.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #5 of 7 Old 05-03-2012, 08:02 PM Thread Starter
09YellowJK
2009 JK Wrangler
Ok, so a Detroit Truetrac IS a good choice for rear of a daily driven JK? I'm not doing any hardcore wheeling. And I have an Aussie locker for the front axle already.
post #6 of 7 Old 05-03-2012, 08:14 PM
stokerdog
Yes, Locked front and TT rear is a great setup for a DD weekend warrior.
HST
post #7 of 7 Old 05-04-2012, 12:45 PM
wendell
1987 YJ Wrangler
I run the the tru-trac in both ends of my yj, they are awesome, as close to haveing a locker without having a locker. They are a gear driven LSD with no clutch packs or modifiers. There's allways a percentage of power going to both wheels like a locker, just not a 50/50 split. The most power going to the wheel with most traction. You can over ride this with light brake presure to get more of a 50/50 split like a locker. Unless you are an extreme rock crawler, the tru-trac is a great choice for most situations and has great street manors. Because my jeep spends 90% of it's time on the street and I just trail ride, I went with the tru-tracs. It's a strong practicle unit for most off road applications and is far superior to a factory LSD.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
Old Alpine Amp - Worth installing? joeranger Audio, CB & Ham Radios, GPS, & Electrical 1 07-18-2011 03:55 PM
Installing factory rear bumper, and aftermarket trailer receiver hitch. Goldenknob Technical Articles & Write-Ups 2 03-06-2010 04:23 PM
Installing Sahara factory side step nutserts nut inserts to frame rubicon4x4 General Jeep & Off-Road Equipment 10 01-03-2010 10:16 PM
What is my used TrueTrac worth? BYuen General Jeep & Off-Road Equipment 4 05-03-2009 04:33 PM
TrueTrac ??'s Jakemd98 Engines & Drivetrain 11 10-02-2006 10:34 AM
