true trac or lockers - JeepForum.com
post #1 of 38 Old 07-15-2013, 06:55 PM Thread Starter
Tim05LJ
whats better true tracs or lockers ? I'm not a hardcore 4wheeler, just like to explore back country stuff. Have 33's with a 3.5 rubicon.
Tim05LJ is offline
post #2 of 38 Old 07-17-2013, 06:50 PM
BlueRubiconrich
lockers are 100 % traction, a limited slip is Ok but does not beat a locker.
With a locker you can have a tire off the ground and still drive the other tire.
You can't do that with a limited slip.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #3 of 38 Old 07-18-2013, 12:10 AM
Chewtoy
1976 CJ5
not trying to be an @$$ but do a search on it, there are a metric ton of threads on this very topic. It really depends on what the kind of wheeling you want to do and the on road driving characteristics you want to have.
There are people that will swear by every combination of open/LSD/locker combination ever made. Do a few days of reading and get an idea of what you want.
With a great Jeep comes an empty wallet.
Chewtoy is offline
post #4 of 38 Old 07-18-2013, 04:28 PM
TJ_Virgin
Imo if you got the money, go with selectable lockers. The dif's are open until you flip the switch. Then they are locked.
TJ_Virgin is offline
post #5 of 38 Old 07-22-2013, 02:26 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
You ought to due some research about the question posted as the Truetrack is a GEAR driven limited slip and it does in fact turn the tire on the ground with the other in the air, just a bit slower.
But don't take my word for it...
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #6 of 38 Old 07-23-2013, 10:15 AM Thread Starter
Tim05LJ
I'm not a hardcore 4wheeler more about exploring the back country. Looks like I'm going with true tracs. Thanks for the input guys
Tim05LJ is offline
post #7 of 38 Old 07-23-2013, 10:26 AM
RWKHaus
1990 XJ Cherokee
KEEP IN MIND. A Tru Trac does Not work in reverse. I know big deal right. Wrong.
So your cruising down a fire road (be it in mud, snow or even sand) and you see a nice off shoot that you want to explore. You drop it in 4WD and head off to explore. The front tires get off the hard pack, and then the rear tires do, and you sink in to very soft stuff. Thats it, no more progress. A very common situation.
Now you put it in reverse to get back to the hard pack and all you have is a open diff and one tire spinning.
Or even in rock and you get over a bolder and wedge into a pinch and your rocker is on the bolder. The tru trac got you there with both tires spinning and now to back out you only have one, and that one tire is the tire with least traction or in the air.
I just know that about 1% of the population knows this about a tru trac and it needs to be considered when choosing.
Brook "He kissed me at KOH, you should ask him about it"
RWKHaus is offline
post #8 of 38 Old 07-23-2013, 12:43 PM
schitzangiggles
King of Macastan
I have never had that happen in reverse. I guess mine was defective.
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #9 of 38 Old 07-23-2013, 12:48 PM
RWKHaus
1990 XJ Cherokee
yeah I guess Eaton made on special one, that you just happen to get
Look at the design and how you have to buy the correct for the rear or front, depending on direction of drive and you will understand...
RWKHaus is offline
post #10 of 38 Old 07-23-2013, 05:24 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
jeepdaddy2000 is offline
post #11 of 38 Old 07-23-2013, 06:25 PM
IslandTJ
In my experience the TrueTrac does work in reverse. Here's a vid of my fronts in forward action
IMO TrueTracs are great for daily driven Jeeps who experience frequent winter snow and icy conditions. However, TrueTracs will demonstrate their weaknesses if you lift your tires often or rock crawl. I've been running front and rear TrueTracs for over 6 years and I am very happy with the performance they provide me in the Pacific Northwest.
Now Jeeping in Oregon
IslandTJ is offline
post #12 of 38 Old 07-23-2013, 11:07 PM
schitzangiggles
King of Macastan
And you should slow your roll before you throw a product under the bus because you heard something from your BFF and have a bias based on second hand conjecture and not fact.
So what exactly prevents it from working in reverse? A ratcheting pawl? George Boosh? What?
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #13 of 38 Old 07-24-2013, 12:07 AM
schitzangiggles
King of Macastan
http://www.jpmagazine.com/techarticl...w/viewall.html
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #14 of 38 Old 07-24-2013, 08:38 AM
RWKHaus
1990 XJ Cherokee
Pure physic's and design...
Its a helical cut gear design that when one axle is starting to spin faster then the other, then the pinion gears inside ramp up and by doing so then engage each other more firmly and causes them to not want to allow such a difference in axle speeds. When in reverse that ramping up, is the opposite. It stays in the most open condition it can.
A open diff at times will also seem like both tires are being driven equally. But by design and mechanics, its just an open carrier that in that one case might just seem like a posi..
I am a Differential store Owner that has installed more differentials, gears, axle, etc then ALL YOUR BFF's and family and people you know all added together. I think I have a little more professional and accurate information then yourself.. Good try though.
I would never Throw the Tru trac anywhere. Its extremely strong, well made and reliable. Only just like a insert locker has flaws, so does this. I am sorry I just insulted your beloved tru trac with a fact you didnt want to hear.
RWKHaus is offline
post #15 of 38 Old 07-24-2013, 04:40 PM
jeepdaddy2000
1971 CJ5
Odd, the video clearly shows the diff operating when the brakes are applied, loading the "light side" axle. I run a Gleason in the rear of my CJ and it operates the same way, in both forward and reverse.
