truck avenger 470 issues - JeepForum.com
post #1 of 6 Old 02-19-2012, 07:53 PM Thread Starter
joelknopp
1948 CJ3A
first time i've posted, was running a edelbrock 1406 that i had jetted according to edelbrock's suggestions on my 3.8 buick, it ran well except for flooding/dying on uphill angles, now i have a truck avenger 470 on there and it runs like crap, haven't tried it out offroad yet, just huge loss of power and bogging/stumbling at mid-high rpm, (i'm assuming that's when the secondaries open), and no power uphill, the tips of my spark plugs are dry, and show good color, but have strong gas fumes coming out the exhaust, seems like this thing dumps out alot more fuel than the edelbrock did, i'm sure lots of ppl are running this setup, how did you make it work? any advice would be great!
joelknopp is offline
post #2 of 6 Old 02-19-2012, 09:01 PM
BSInc
Have you set your float levels and try different secondary springs. these are where I had to start with my 470.
BSInc is offline
post #3 of 6 Old 02-19-2012, 09:15 PM Thread Starter
joelknopp
1948 CJ3A
set float to the bottom of the clear plastic "windows", bought this carb used, and the guy had 2 of them, the extra spring he gave me was the black one as well, got 2 of the same heavier spring, so it's opening the secondaries later, higher rpm, don't think that'd hurt it, could be wrong, did you change your jets? i am at 5000 ft, i know it will be running richer than at sea level, but enough to cause these issues?
post #4 of 6 Old 02-21-2012, 04:07 PM
Chewtoy
1976 CJ5
I hated my 470, never could get it tuned, same kind of problems, finaly gave up and put a JY fuel injection on.
That being said, search for posts by JeepHammer, he has several amazing writeups on here as to how to tune a Holly. Having worked for them for several years, he has some great advice.
With a great Jeep comes an empty wallet.
Chewtoy is offline
post #5 of 6 Old 03-01-2012, 10:47 PM Thread Starter
joelknopp
1948 CJ3A
hahahaa! just empty every pocket, right? thanks
post #6 of 6 Old 03-01-2012, 10:49 PM Thread Starter
joelknopp
1948 CJ3A
the guy at holley says there's a problem with the check valves in the metering blocks, some kind of factory defect, gotta send it in
Truck Avenger vs TBI grizzly11 Engines & Drivetrain 6 09-27-2011 11:32 AM
Need Advice-Truck Avenger on 304 OldCJ Engines & Drivetrain 0 02-22-2011 01:54 PM
Installing Truck Avenger HASBEEN Engines & Drivetrain 0 11-09-2009 03:29 PM
holley truck avenger bowerg General Jeep & Off-Road Equipment 6 03-26-2007 08:02 AM
Holley truck avenger just enough Engines & Drivetrain 3 09-12-2005 05:30 PM
