Trouble starting, cranks forever - JeepForum.com
post #1 of 4 Old 11-26-2010, 12:41 PM Thread Starter
ramblin-man
1987 FSJ Wagoneer
I have an 87 Wagoneer, the small ones that are basically the same as a Cherokee, not the Grand Wagoneer. It has got to where I have to crank it for like 45 seconds straight until i hear the fuel pump kick on and it starts. I took it to a shop last a few months ago when this happened before and they replaced a sensor and it worked fine. It's happening again though and if it's a sensor or something I can replace myself, I'd rather do it. Any ideas what it is that could cause this and why it's happening again?
ramblin-man is offline
post #2 of 4 Old 11-26-2010, 12:57 PM
crem
If you can explain the start up problems better I MIGHT be able to help..
What I mean is on my first cherokee, it would have problems starting, I would turn the key and nothing, keep turning and turning untill I could hear a very faint gurgling sound, I would then wait and it would get louder and louder untill finally I could hear the fuel pump fully come on and then the start up would be cake.
Does this sound like your gremlin?
1992 White (SOLD)
1993 Green (SOLD)
1998 Red XJ - Stock for now
crem is offline
post #3 of 4 Old 11-26-2010, 11:27 PM Thread Starter
ramblin-man
1987 FSJ Wagoneer
well the starter will turn over for about a minute straight before i hear the fuel pump kick on and it starts. i called my mechanic and they said they think it is the crankshaft position sensor. does that sound right?
post #4 of 4 Old 11-27-2010, 04:47 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
It could be, but it's just a guess. Could be the fuel pump relay. Another guess. Testing is the best way to a solution. If it exhibits these symptoms regularly, it can be diagnosed by someone qualified to do so.
cruiser54 is offline
fuel pump , sensor , starting problem
starting trouble JRink Engines & Drivetrain 4 02-09-2011 09:48 PM
YJ missing and trouble starting tater_kamik Engines & Drivetrain 0 04-29-2010 05:16 PM
4.0 cranks but won't start Gabejeepxj99 General Jeep & Off-Road Equipment 1 08-17-2009 07:10 PM
oil pressure and starting trouble on 4.0 24Fan Engines & Drivetrain 1 06-29-2009 09:20 PM
forever black question crawlr Cheap Tricks & Fixes 5 04-14-2009 02:07 PM
