trouble after engine swap 3.7L. different crank position ring on crank - JeepForum.com
post #1 of 2 Old 06-10-2009, 06:07 PM Thread Starter
nubby
swapped 03 3.7L(k code) and installed a 04 3.7L(k code). after the change had lots of trouble getting the engine to start and after it started it ran horribly. after some checking around found that the crank position ring is different from the engine we pulled out, the width of the notches are different. what would be the best way to go about fixing this issue, change the cranks out? get a new pcm from an 04? get my pcm reflashed with the change in values @ crank position pickup? any help would be greatly appreciated, thank you in advance
~nubby
a few days later..... here is where we are at. any help????? we decided to swap the cranks out. put the 03 crank in the 04 engine, it is running and not having trouble getting it to start but now it is missing like crazy and idling very high (990rpm). compression test is good, coils good, plugs good, fuel pressure good, put a obdII reader on it and no codes. the scanner shows that the timing is 3deg btdc. does anyone know if the cams in these 2 engines are different also?
nubby is offline
post #2 of 2 Old 06-13-2009, 06:48 PM Thread Starter
nubby
anyone have any info to help???
have put so much money into this and i am hoping not to have to start over. multiple sources from shops around said that these 2 engines were compatible, too bad i didnt come here first i would of known to get an 02 or 03 and NOT an 04.
~nubby
nubby is offline
Engine will turn over but will not crank mek Audio, CB & Ham Radios, GPS, & Electrical 1 01-25-2009 08:02 PM
Engine does not crank unless i use starter fluid McElwain_USMC Engines & Drivetrain 3 10-07-2008 07:33 PM
4.2./258 crank spyder6 Engines & Drivetrain 0 05-18-2008 08:38 PM
Flywheel/Driveplate/Flexplate and Crank Position Sensor jeeprad Engines & Drivetrain 2 11-29-2002 11:01 PM
engine swap ignition trouble.... HELP! '79 CJ-7 Levi Engines & Drivetrain 1 06-28-2002 05:12 PM
