Transmisson? - JeepForum.com
post #1 of 9 Old 03-20-2013, 12:08 AM Thread Starter
samoedin
Transmisson?
Hey everyone! I have a 2.4L MT 03 tj it's hard to shift to 1st and 2nd gear when it's cold less often when it's warmed up also lately I have been feeling a multiple kicks with 2nd and 3rd on acceleration low speed and last thing is when driving on 4th gear on 40mph sometimes the RPM goes high and back to normal with out effecting the acceleration. I have a bad cat converter and a O2 sensor that I'm replacing soon but would that effect the transmission/performance? Thanks.
samoedin is offline
post #2 of 9 Old 03-20-2013, 02:30 AM
mmerlinn
No.
mmerlinn is offline
post #3 of 9 Old 03-20-2013, 02:54 PM
seattle_yj
Yes. Just kidding, no.
seattle_yj is offline
post #4 of 9 Old 03-20-2013, 03:14 PM Thread Starter
samoedin
Lol what is it then?
samoedin is offline
post #5 of 9 Old 03-20-2013, 04:21 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Sounds like a clutch issue, either worn or binding.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #6 of 9 Old 03-20-2013, 04:35 PM Thread Starter
samoedin
I see. Well this is started happening after I put 33" tires! Also the most I can't is 60mph barely keeping it flat on 5th!
samoedin is offline
post #7 of 9 Old 03-20-2013, 04:37 PM Thread Starter
samoedin
Most I can go is 60mph***
samoedin is offline
post #8 of 9 Old 03-20-2013, 08:41 PM
GilaMtnJeep
I just reread the op, you say you have a bad cat? Define bad - is it blocked or collapsed? Restriction in the exhaust like that could help to explain the 60mph limit flat in 5th. May have nothing to do with the clutch. If you're replacing the cat anyway because it's bad this may not hurt emmissions so what I am about to say will not be too bad. Drop the cat and poke something through it from inlet to outlet a few times. That will "open it up". If you run better and can hold higher speeds better afterwards you have your answer, after all it's slated for replacement anyway.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
post #9 of 9 Old 03-20-2013, 09:22 PM Thread Starter
samoedin
I have was getting 420, 141 ,031 and 132error codes. What I did I took out the up stream o2 sensor and drove few blocks then I put back in and then i did a rest by taking out the battery. All codes were cleared. Been driving for 4 hours and I was able to go up to 75mph on 4x4 and no more kicks. I already order the magnaflow 51006 cat and the ntk upper lower sensors I'm just gonna replace them anyways since I have 200k miles on my TJ and see if the will I'm prove performance.
samoedin is offline
