Transmission and transfer case problems - JeepForum.com
post #1 of 3 Old 02-13-2011, 06:21 PM Thread Starter
Apesteguy
Hi Everyone,
Im new the the forum. I just bought a 97 jeep tj 2.5l 4 cyl automatic. It seems like in the morning when the engine is cold and i put it into drive and try to move it will just rev a bit and not move but then it will go and it seams fine after that. only does it the once. Also when i try to shift from 4low back down to 4 high or 2 high i get snapping and cruching noises. any ideas what might cause these issues?
Apesteguy is offline
post #2 of 3 Old 02-13-2011, 06:30 PM
mike481
mike481's Avatar
Have you checked your transmission fluid level? What speed are you shifting out of 4lo?
Chuck- A better dog than I could ever deserve
RIP 4-14-2012
mike481 is offline
post #3 of 3 Old 02-13-2011, 06:32 PM Thread Starter
Apesteguy
the fluid is toped up. and i only shift from 4 low when stopped and in nuetral. I didnt think you could shift from 4 low while moving.
Transmission and Transfer case replacement efelito Engines & Drivetrain 0 09-16-2010 06:28 AM
transmission/transfer case ???? supermopar77 Engines & Drivetrain 1 10-08-2009 10:22 AM
94 yj transfer case problems renegadeyj Engines & Drivetrain 4 12-19-2007 05:34 PM
transfer case or transmission issue? cali_XJ Engines & Drivetrain 3 05-24-2006 08:21 PM
Transfer Case Problems WarnRocker79 General Jeep & Off-Road Equipment 2 12-20-2001 03:35 PM
