-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   transmission problem (http://www.jeepforum.com/forum/f19/transmission-problem-1979394/)
bstalion23 01-09-2014 09:02 PM
96 Jeep grand cherokee limited 5.2 v8.
dash showed "Trans over heat" and reverse does not work now. Got stuck in snow and rocked it back and forth, and ran into this problem. Any help out there?
Sent from my DROID RAZR HD using JeepForum
laybackman 01-10-2014 07:39 PM
I would check the tranny fluid level once the tranny is hot and in neutral on level ground.
bstalion23 01-10-2014 08:33 PM
I was told I burned the reverse band out.is this true
laybackman 01-10-2014 08:37 PM
If the fluid level is not the issue, it is a distinct possibility.....:(
jnicewan 01-11-2014 12:43 AM
The rear band is for low/reverse, and applied in those positions only. The band is applied in manually shifted low gear for engine braking effect. So, you will still have low gear if the band failed but see if you have engine braking when you let off the throttle. Shift trans to the manual 1st/low position and accelerate to higher speed for 1st gear then let off the throttle. If engine speed drops to idle or near idle then the band is not applying, if engine decelerates with the vehicle speed then the band is applied.
The time now is 04:55 PM.
