Transmission Leak - JeepForum.com
post #1 of 4 Old 01-16-2002, 06:30 PM Thread Starter
Dustin Maschino
Transmission Leak
I have an 82 CJ-7 with and automatic and it leaks, the gasket has been changed twice already...
does anyone know why it keeps leaking?
Dustin Maschino is offline
post #2 of 4 Old 01-16-2002, 06:34 PM
evilpsych
evilpsych's Avatar
is it leaking from the gasket? and.. is it a cork gasket?
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 4 Old 01-16-2002, 06:44 PM Thread Starter
Dustin Maschino
im not sure
i bought it and the previous owner had changed it twice, and it needs it again...
post #4 of 4 Old 01-17-2002, 06:30 AM
glm 87 wrangler
I have an auto tranny in mine too.What type is yours.I think mine is a 727 but someone else said it might be a 999 not sure yet but i will find out.As for your leak is it the pan?? Most times if its the pan its probably
got over tighten and bent the pan at the bolt holes which is very common.The problem is getting it back to were it will seal.You can try a sealer only to see if that works its more forgiving and will mate up better.The other solution would be to replace the pan and gasket.The sealer is a cheaper solution just be careful not to over do it.My rear seal on my tranny is leaking, going to have to drop the T Case to get to it.FUN!! Well hope this helps...Gary
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
early transmission or later transmission? wannacuda Engines & Drivetrain 0 08-11-2009 02:17 PM
Transmission Leak 700r4 Simple fix right ? JeepFan07 Engines & Drivetrain 3 01-04-2009 03:11 PM
oil leak HELP!!!!!! eche981 Engines & Drivetrain 3 07-09-2008 04:55 PM
XJ 4.0L HO Oil Leak gumbo76 Street Jeep Forum 1 01-24-2007 09:47 PM
oil leak 83 cj-7 258 Engines & Drivetrain 1 05-28-2004 03:52 AM
