transmission bolt - JeepForum.com
post #1 of 5 Old 07-17-2013, 04:05 PM Thread Starter
toybox30
transmission bolt
Hello my son removed a bolt on the drivers side of his t-5 transmission. Now i cant get it to slide back into place any info would be great.Hope its not the do not remove bolt no spring or ball fell out.
toybox30 is offline
post #2 of 5 Old 07-17-2013, 04:43 PM Thread Starter
toybox30
from a jeep scrambler if that matters
toybox30 is offline
post #3 of 5 Old 07-17-2013, 05:27 PM
Holder350
1995 XJ Cherokee
Looks like the slack adjuster for the release fork...... but the only T5 I have is in a GM
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #4 of 5 Old 07-18-2013, 03:01 AM
mmerlinn
That is not a bolt. That is the pivot pin for the reverse shift lever. Only way to fix it is to remove the top cover, screw it back in while aligning the reverse lever, then re-installing the retaining clip that you will find in the bottom of the transmission.
mmerlinn is offline
post #5 of 5 Old 07-18-2013, 06:17 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yup. Had a tech do that at the dealership I worked at many moons ago. Shoulda left him working on VWs I guess.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
