transfercase grinding w/video. - JeepForum.com
post #1 of 14 Old 09-30-2012, 12:30 AM Thread Starter
seattle_yj
I'm having an issue with my np231.
Video can be seen here: http://youtu.be/w44T7AeKr-4
When I shift from 2H to 4L, drive a bit, then try to shift from 4L to 4H or 2H, I get this grinding. I'm wondering if anyone has experienced this? My thoughts are that it is the shift fork. Do you know if the back half of the case can be removed with the tcase still installed in the vehicle and the shift fork be inspected, replaced?
I posted this in the YJ section with no love, so hopefully you guys can help me here and share your experiences.
seattle_yj is offline
post #2 of 14 Old 09-30-2012, 12:40 AM
Kodiak17
Are you shifting while driving, cause mine grinds when I do that. But yea, you can pull the back half off with it under the jeep. You mind as well pull the whole thing at that point though.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #3 of 14 Old 09-30-2012, 01:37 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Normal.
When you pass through N, the auto trans starts spinning the output shaft. You need to shift it VERY quickly, put the trans in P prior to shifting (this can cause the t cast to not shift at all), or shut off the engine.
jeepdaddy2000 is offline
post #4 of 14 Old 09-30-2012, 02:31 AM Thread Starter
seattle_yj
thanks for the reply's guys. My procedure goes like this. While stopped, put the auto trans in N. Take the tcase from 2H to 4L. Shift from N to D. Drive a bit. Stop. Put Trans from D back to N. Put tcase from 4L to 2H. Then when I go from N to D, it will start to grind. At that point, I just shift in combinations of 4L to 2H while in Park or N. It will finally engage after I repeat the process from 2 - 20 times. My fear is that I will be out wheeling/camping and will get stuck in 4LO and not be able to make it home.
post #5 of 14 Old 09-30-2012, 09:43 AM
flippy5x0
mines an automatic tj, but i went to shift into 4 lo and when i shift back into 2h, if i dont put the gear shifter into neutral first then it will do that. if it is in neutral and i start to hear it, i just take my foot off the brake, let it roll like a cm and try again, works fine
flippy5x0 is offline
post #6 of 14 Old 09-30-2012, 09:54 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If you get grinding while shifting, you are either shifting incorrectly, or the the shifter mechanism needs adjusting so that you are fully engaging each mode in the transfer case. Grinding indicates partial engagement.
The T-Case can be split while still in the Jeep. You may want to buy and install a new chain and new shift fork tabs while you have it apart. They are normal wear items that need replacement when worn out.
CJ7-Tim is offline
post #7 of 14 Old 10-01-2012, 03:57 PM Thread Starter
seattle_yj
I'm definitely shifting correctly. Placing in N and shifting from a full stop is the correct procedure. The linkage is correct and I'm in the proper engagement positions. The chain is new. I think it is warn shift fork tabs that creates enough slop to not engage correctly. Well, I'll make ready the trans jack and pull it out and crack it open. FUN!
post #8 of 14 Old 10-01-2012, 06:01 PM
CJ7-Tim
CJ7-Tim's Avatar
I would suggest disconnecting the shifter linkage and shifting the T-Case by hand using the mode lever on the T-Case. If the symptoms are go away, you have a linkage issue, is they persist, you have a T-Case issue.
CJ7-Tim is offline
post #9 of 14 Old 10-01-2012, 07:38 PM Thread Starter
seattle_yj
I'll give that a try. Thanks for the responses.
post #10 of 14 Old 02-07-2013, 11:03 AM Thread Starter
seattle_yj
I pulled this last night and took everything completely apart. I did see some metal dust stuck to the magnet in the bottom of the case but I see no visible ware on any of the gears, the bearings seem good, the shift fork pads are in good working order, the aftermarket chain looks good. The only thing I don't like is the amount of force used to change gears. I think it should more fluid but I'm not sure. Any ideas on parts /pieces I should check?
post #11 of 14 Old 02-07-2013, 11:47 AM
MattNey723
If it continues after u put it together try holding the lever in 4low... if that works its something worn in the linkage...
MattNey723 is offline
post #12 of 14 Old 02-07-2013, 02:29 PM Thread Starter
seattle_yj
The linkage had been replaced with the following.
post #13 of 14 Old 02-07-2013, 02:54 PM
MattNey723
Huh very well lol
post #14 of 14 Old 02-08-2013, 10:41 AM Thread Starter
seattle_yj
Could the grinding be caused by a failing synchro ? That's just my swag at this point.
np231 , shift fork. , transfercase
Trying to remove transfercase HAYSHAKER170 Engines & Drivetrain 2 12-29-2011 04:26 PM
241c transfercase divco13 Engines & Drivetrain 3 03-14-2011 04:45 PM
Transfercase issue Bluejeep88 Engines & Drivetrain 1 01-31-2011 10:14 PM
Transfercase will not adjust.. wow682 General Jeep & Off-Road Equipment 0 06-30-2009 11:23 AM
transfercase ? please help wrangler 06 Engines & Drivetrain 1 11-08-2006 03:13 PM
