Transfer swap: NP249 to NP232 - JeepForum.com
post #1 of 5 Old 03-20-2013, 07:55 PM Thread Starter
Forge04
I know there are a ton of threads and subjects dedicated to this already. My questions are detailed.
I have a NP249 that is done and dead. It's input shaft is 23 spline. I have the tags w/dates in this order: dead NP249, newer NP231, newer NP249.
Based off of these tags, will the NP231 bolt right in?
Forge04 is offline
post #2 of 5 Old 03-20-2013, 07:57 PM Thread Starter
Forge04
Also, I'm headed to the junkyard to get one of those within the hour.
The newer NP249 is out of a ZJ. The newer NP231 is out of an XJ. Unknown years and engines.
My other thought, I should be able to switch input shafts as a last resort correct?
Forge04 is offline
post #3 of 5 Old 03-20-2013, 08:00 PM Thread Starter
Forge04
Thirdly, feel free to text replies as well as post them 208-8eight0-9862
Forge04 is offline
post #4 of 5 Old 03-22-2013, 12:40 AM
seattle_yj
I think you were the one from another thread on this and I may have already stated this info. My only advice is that you match the input shafts. There are 3 lengths, 2 bearings widths, 2 gear cuts, 2 spline counts. None of which are interchangeable.
Your drive shaft lengths may be different as well.
seattle_yj is offline
post #5 of 5 Old 03-22-2013, 01:20 PM Thread Starter
Forge04
I was yeah. I was just looking for someone that could look at those tags and give me an answer. I was on the road
Thanks though!
I'll put the resolution in that other thread.
Forge04 is offline
