transfer case swap help - JeepForum.com
post #1 of 4 Old 04-27-2012, 01:45 PM Thread Starter
Aimee
Hi, I'm looking for help with a transfer case swap. My teenage son has a 1993 wrangler. Some how the drive shaft to the front of the transfer case (at the u joint) broke off, it must have smashed into the transfer case and cracked it wide open. So, in an effort to save money, he purchased another one from someone who was parting out a 1994 wrangler. We had spent a whole afternoon trying to put the "new" one on. Well it appears the gearshaft coming from the tranny (our jeep) that should fit into the transfer case (the "new" part) is too big. Is there anything we can do? I guess what I'm asking is, are the two input gears able to be switch out? And how?
Aimee is offline
post #2 of 4 Old 04-28-2012, 12:53 AM
1986cj
Count the splines on your trans and the transfercase. If you have a AX15 you should have 23 slpines and a np231 transfercase. The 4cyl (AX5) uses the same np231 transfer but the 4 cyl only has 21 splines. This may be your problem.
1986cj is offline
post #3 of 4 Old 04-28-2012, 05:08 AM
Technohead
It should be possible to swap the input shaft from the old t-case to the new t-case.
-Eric
Technohead is offline
post #4 of 4 Old 04-29-2012, 10:57 AM
dadstoy
The input shafts can be swapped. You just need to disassemble the two cases and swap the main/input shaft(s). Just keep the different pieces in order as you take them out so they go back in in the correct order.
dadstoy is offline
transfer case swap lynusann Engines & Drivetrain 5 01-02-2012 02:56 PM
transfer case swap 96 249 to a 99 231 jasonwdm Engines & Drivetrain 0 09-25-2011 09:06 PM
transfer case swap jeepwrangler1 Engines & Drivetrain 1 08-27-2010 09:20 AM
Transfer Case Swap JonnyCartee Engines & Drivetrain 1 12-17-2008 01:25 AM
transfer case in the 4.0 swap.. mbe25 Engines & Drivetrain 6 03-22-2007 12:28 PM
