Transfer case HELP!! - JeepForum.com
post #1 of 6 Old 07-17-2013, 01:40 PM Thread Starter
TMC23
I blew a hole in my transfer case the other day now im looking for a replacement... I drive a 95 YJ 4cyl 5speed, I have a buddy with a np231 out of a 96 cherokee with an automatic, will that work or will it not fit?? i did a few searches and couldn't find the answer... any help is much appreciated! Thank You!
TMC23 is offline
post #2 of 6 Old 07-18-2013, 03:57 AM
mmerlinn
Probably won't work. Check the input spline counts. Bet they are different.
mmerlinn is offline
post #3 of 6 Old 07-18-2013, 05:29 AM
Holder350
1995 XJ Cherokee
Input shafts may be different, but you can swap them out.
Sent from my phone
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #4 of 6 Old 07-18-2013, 04:38 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Sent from my phone
Pay attention to the length, too. I believe they are different from auto to manual trans.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #5 of 6 Old 07-18-2013, 06:21 PM
Holder350
1995 XJ Cherokee
I know spline counts changed from pre to post HO.
I have personally swapped a xfer case from an auto to a manual (92 model) and they were the same length.
Best option is to pull it and see.....if they are not the same, start taking them apart and swap the input shafts. Its not a hard job and shouldn't take over a couple hours
Sent from my phone
post #6 of 6 Old 07-22-2013, 10:41 AM Thread Starter
TMC23
Thanks for all the help guys! I Found a used transfer case from a 95 yj with a 5speed so it should bolt right up. Thanks again!
TMC23 is offline
