-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   Transfer case HELP!! (http://www.jeepforum.com/forum/f19/transfer-case-help-1550181/)
TMC23 07-17-2013 01:40 PM
I blew a hole in my transfer case the other day now im looking for a replacement... I drive a 95 YJ 4cyl 5speed, I have a buddy with a np231 out of a 96 cherokee with an automatic, will that work or will it not fit?? i did a few searches and couldn't find the answer... any help is much appreciated! Thank You!
mmerlinn 07-18-2013 03:57 AM
Probably won't work. Check the input spline counts. Bet they are different.
Holder350 07-18-2013 05:29 AM
Input shafts may be different, but you can swap them out.
Sent from my phone
GilaMtnJeep 07-18-2013 04:38 PM
Sent from my phone
Pay attention to the length, too. I believe they are different from auto to manual trans.
Holder350 07-18-2013 06:21 PM
I know spline counts changed from pre to post HO.
I have personally swapped a xfer case from an auto to a manual (92 model) and they were the same length.
Best option is to pull it and see.....if they are not the same, start taking them apart and swap the input shafts. Its not a hard job and shouldn't take over a couple hours
Sent from my phone
TMC23 07-22-2013 10:41 AM
Thanks for all the help guys! I Found a used transfer case from a 95 yj with a 5speed so it should bolt right up. Thanks again!
The time now is 03:58 PM.
