transfer case in the 4.0 swap.. - JeepForum.com
post #1 of 7 Old 03-14-2007, 02:04 PM Thread Starter
mbe25
interesting situation i think...
the np231 with the 23 spline was in my yj with the 2.5. i dont know why it was but it is.. i thought they are always the 21 in the 4 cylinders..but anyway..
i got an aw4 out of a cherokee and the input shaft on the transfercase is too long and it bottoms out in the tranny when you try to mate them. i dont know why this is happening, as i thought they were all the same.
i think im going to try and cut the dam thing. what could possible happen bad? if i take the time to cut it neatly and file the edges, the bolt patter on the housing lines up and the splines mesh perfectly....
input?
mbe25 is offline
post #2 of 7 Old 03-18-2007, 01:28 PM Thread Starter
mbe25
bump. please
mbe25 is offline
post #3 of 7 Old 03-19-2007, 01:15 PM Thread Starter
mbe25
ok so maybe at least someone can tell me if they have heard of this problem.
mbe25 is offline
post #4 of 7 Old 03-19-2007, 01:37 PM Thread Starter
mbe25
either this solution or get a custom "adapter spacer plate" made from some high end billet aluminum, which i am quite sure this would be expensive...
mbe25 is offline
post #5 of 7 Old 03-19-2007, 01:53 PM Thread Starter
mbe25
ok, i found some info out, if ANYONE cares...
the tf999 which is what was behind my four banger comes with a np231 with a long shaft, and on the aw4, they are short..
http://www.novak-adapt.com/knowledge/np231.htm
mbe25 is offline
post #6 of 7 Old 03-19-2007, 02:05 PM
1rockhead
On Stu Olson's website they had a similar problem and cut it down.
stu-offroad.com
1rockhead is offline
post #7 of 7 Old 03-22-2007, 11:28 AM Thread Starter
mbe25
i was going to just cut mine down, but then a friend brought up a good point. if it isnt cut perfectly straight, it will be out of balance and that could lead to some bad vibrating..
mbe25 is offline
NP 231 transfer case. chain slapping case jetmech135 Engines & Drivetrain 1 01-01-2010 05:49 PM
Tranny and transfer case swap brandongee Engines & Drivetrain 1 01-25-2009 04:33 PM
Transfer Case Swap JonnyCartee Engines & Drivetrain 1 12-17-2008 12:25 AM
Trans/Transfer case swap gasmandave Engines & Drivetrain 1 09-11-2008 03:56 AM
Transfer case ID Toddmw Engines & Drivetrain 9 07-19-2007 11:33 PM
