Trans OD issues - JeepForum.com
post #1 of 5 Old 02-23-2014, 07:10 PM Thread Starter
Jmwild96
Trans OD issues
Hi All
96 cherokee 4.0 200k but 40k on rebuilt trans. No tow or plow. Accelerating onto tollway, won't accelerate beyond 55mph, then with more throttle RPM jumps 1200+ to about 3K with no response from trans (speed) - seemingly slipping. Pull over, smell burned trans smell. Fluid full but burnt. 1st-3rd gear fine, but seemingly won't shift into OD, and still smells hot/burnt. Likely bad trans/losing OD or possibly TCM or something else?? What to do?? Work truck without means of replacing it right now, but no work without it. Help! Thanks!
Jon
Jmwild96 is offline
post #2 of 5 Old 02-25-2014, 02:05 PM
rcondon
My 96 cherokee does the same thing. If you find a cure let me know thanks. I've had no luck with mine yet.
rcondon is offline
post #3 of 5 Old 03-01-2014, 05:36 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Have you changed the fluid?
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #4 of 5 Old 03-01-2014, 06:41 PM
redwolf698
Converters smoked from the sounds of things.
Daniel J Fenti
Owner - NC Transmission
2004 WJ Overland lightly modified
Boat Drinks OffRoad Co-Founder
redwolf698 is offline
post #5 of 5 Old 03-02-2014, 08:33 AM
GilaMtnJeep
GilaMtnJeep's Avatar
Sounds like something a tear down will fix. When the Trans goes into OD the TCC (TC clutch) engages and gives you OD. If the fluid is dark/burnt smellin and don't go into overdrive then it sounds like the clutch is possibly done and/or there is a problem in the valve body. To be sure get a professional diagnosis.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
overdrive , transmission help
