Trans Not Going into Gear. - JeepForum.com
post #1 of 8 Old 06-12-2013, 04:49 PM Thread Starter
Mudslut77
87 Wrangler 4.2 inline. Trans been having problems. Will not go into gear. Bled the clutch, new slave cylinder still nothing. I think my next move is a clutch master cylinder... What do y'all think?
Mudslut77 is offline
post #2 of 8 Old 06-12-2013, 08:12 PM
rd94yj
Could possibly be bad syncros. Ax15? Miles?
94 YJ 60/14 bolt 4.0 ax15 Dana 300
88 YJ 60/14 bolt AMC 360 nv4500 np241
rd94yj is offline
post #3 of 8 Old 06-12-2013, 08:35 PM Thread Starter
Mudslut77
Rebuilt motor. Peugeot trans.. Been sitting for 2 years. Motor has 2000 miles..
post #4 of 8 Old 06-12-2013, 08:36 PM
ezk83
Are you sure clutch isnt bad? I shattered my clutch so no slipping just was done.
ezk83 is offline
post #5 of 8 Old 06-12-2013, 08:46 PM Thread Starter
Mudslut77
The clutch was repaired 800 miles ago..
post #6 of 8 Old 06-13-2013, 07:41 PM
rd94yj
im saying you have a problem with your transmission
rd94yj is offline
post #7 of 8 Old 06-23-2013, 06:00 PM
Aukntrygrl
We have the same transmission and had same problem, changed master cylinder and it fixed the problem.
Well until the slave cylinder started leaking. Did research and that trans has a bad reputation. I would try
changing the master 1st, just watch for leaks from bell housing.
Aukntrygrl is offline
post #8 of 8 Old 06-25-2013, 09:05 AM
LtCdrLange
1997 XJ Cherokee
sounds stupid but when was the last time you change your gear oil? i had the problem in my xj and the oil came out all milky.. once i changed it.. problem solved
LtCdrLange is offline
