tranny - JeepForum.com
post #1 of 8 Old 04-27-2002, 06:36 PM Thread Starter
Dus-10
tranny
Can anybody tell me what kind of tranny a T-85Q-1 is or what kind of motor I could put in front of it?
67 J-3000 pickup 327 V-8 with 3 on the tree
Dus-10 is offline
post #2 of 8 Old 04-28-2002, 10:12 AM
4wheeler4CJ
4wheeler4CJ's Avatar
I can't help ya, DUS,
Do you have any factory manuals you can cross reference? Is it a Jeep tranny? Do you know what it came out of?
(Someone may have a cross-reference link for ya, also?)
4wheeler4CJ is offline
post #3 of 8 Old 04-28-2002, 04:18 PM Thread Starter
Dus-10
the tranny is in a 67 j-3000 pickup with a 327 vigilante. I can't find a starter for the motor so I would like to change to a more common motor without changing the tranny and transfer case.
Dus-10 is offline
post #4 of 8 Old 04-29-2002, 10:12 AM
4wheeler4CJ
I'll check my Jeep book and see what I can find. You should be able to find a starter for the 327 somewhere though, many people still run the 327.
By the way, I think the truck is referred to as the J-30, even in your year (it may say 3000 on the side, but the model is J-30, I'll check that also). <img border="0" title="" alt="[Wink]" src="wink.gif" />
post #5 of 8 Old 04-29-2002, 11:01 PM Thread Starter
Dus-10
I talked to a guy at a local auto electric shop today and he said that if I would leave the truck with him for a few days that he will build me a starter. So I will probably take it to him this weekend. but I would appreciate any info that you could give me.
Dus-10 is offline
post #6 of 8 Old 04-30-2002, 01:49 PM
4wheeler4CJ
That's a good solution to the starter problem <img border="0" title="" alt="[Wink]" src="wink.gif" />
Your tranny, if stock, is the Warner T-85 3-SPD. It was used standard behind the V-8s from 1963-1967 on all the J-Trucks (by the way, yours is actually the Galdiator J2-300, I was mistaken, they changed the designations to J-10, etc. in 1971).
The other trannies used stock are listed below, in case yours was swapped:
Warner T-90A
OHC-6, 1963-1965
Warner T-14A
I-6, 1965-1970
Warner T-15A
V-8, 1968-1970
Hope this helps! Let me know how you make out!
post #7 of 8 Old 05-04-2002, 03:48 AM Thread Starter
Dus-10
Thank you for the information. That is the stock transmission as far as I know. That info will come in handy. thanks again.
Dus-10 is offline
post #8 of 8 Old 05-04-2002, 05:52 AM
4wheeler4CJ
No problem, good luck with it, I've always liked those trucks!!!
Tranny Help!!! 1980 CJ7 Tranny Fill? 80Cjbaby Engines & Drivetrain 1 01-04-2010 03:37 PM
Does anyone what this tranny went in? chiefpontiac Engines & Drivetrain 1 07-07-2008 10:50 AM
tranny help goatlegman Engines & Drivetrain 0 05-30-2008 11:10 PM
Welding the tranny temp sender bung into the auto tranny pan Jerry Bransford Fabrication Shop 10 12-02-2007 08:35 PM
I need tranny help. BlazedXJ Street Jeep Forum 13 06-20-2006 07:22 PM
