Tranmission wiring harness for Cherokee AW-4 - JeepForum.com
post #1 of 5 Old 07-05-2012, 06:00 PM Thread Starter
Knucklehead97
I have a 1997 XJ with an automatic transmission. When it was purchased, there were some wires ripped apart on the transmission. I thought they were for the neutral safety switch, but after replacing it there were still some wires that went inside the transmission that connect to the solenoids. I picked up a used harness and installed it but when I got to the plug on the firewall, it was not the correct plug. Yeah, stupid not to check ahead. Anyway, I am wondering if I can still use it by buying a 7 prong male and female plug, connecting the wires to them and plugging it together. I just need to know if the wires are in the same spot in each plug or are they different. I have made a crude drawing of the 2 plugs with their wiring layout. Is this possible or would the wires need to be in different spots or what. Any info would be greatly appreciated.
Knucklehead97 is offline
post #2 of 5 Old 07-06-2012, 09:03 AM
SECorBust
Let me guess one plug is gray and the other is black. I ran into a similar problem on a 1997? I think the 97 is the ***** SOB. It has no vss on it either if I remember correctly. I was fixing up a 98 using a 97 transmission. I spliced the plugs together somehow. I really can't remember how I did it, but it worked. I think I got lucky.
Really Jeep Forum? Grow up.
http://dictionary.reference.com/browse/*****
***** - strange or odd from a conventional viewpoint; unusually different; singular: a ***** notion of justice.
95 Jeep wrangler 2.5 AX-15 conversion.
SECorBust is offline
post #3 of 5 Old 07-06-2012, 08:19 PM Thread Starter
Knucklehead97
Thanks for the reply. So you just wired it with the wires in the same place as on the plugs?
post #4 of 5 Old 07-06-2012, 08:57 PM
rjbruzan
Using an eyeglass screwdriver you can release the pins from the connector.then install them into you old connector. Ive done this to replace corroded pins in the connector.
Ron
rjbruzan is offline
post #5 of 5 Old 07-07-2012, 11:05 AM Thread Starter
Knucklehead97
I don't have the old connector. It was ripped off the wires, hence this question. I think I can get a new 7 wire male and female plugs. I just worry that the wires are in different locations on the existing plugs. If anyone thinks I can just put the wires in the same locations and plug them together, that is what I'm wanting to know.
Thanks for the reply by the way.
color codes for stereo wiring harness 1999 jeep grand cherokee lmt johnnyl1v3 Audio, CB & Ham Radios, GPS, & Electrical 0 06-17-2012 11:52 AM
ARB Wiring Harness Mousejockey Engines & Drivetrain 1 07-05-2010 10:39 PM
Wiring diagram for the radio harness of a 05 Grand Cherokee? sna77 Audio, CB & Ham Radios, GPS, & Electrical 4 11-11-2006 12:30 AM
Wiring Harness 95 Cherokee (Australia) sasreg Audio, CB & Ham Radios, GPS, & Electrical 1 09-22-2005 10:58 PM
