Track bar and death wobble - JeepForum.com
post #1 of 12 Old 10-30-2012, 08:44 AM Thread Starter
edgonzo11
K guys so last night I was working on putting my lift on my 94 zj but I came across a serious issue. I had to unbolt my track bar in the from diff in order to lower the diff so I could compress the spring. The problem is that now the hole to bolt the track bar back to the diff doesn't align with the hole on the track bar itself. So it doesn't reach. I was able to zip tie it but sure I experienced the scary death warble going 60mph. Has anyone had this issue before? Any suggestions?
edgonzo11 is offline
post #2 of 12 Old 10-30-2012, 12:36 PM
rjbruzan
Turn the steering wheel and it will move the axle into place.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #3 of 12 Old 10-30-2012, 01:34 PM Thread Starter
edgonzo11
We tried doing that and nothing.
post #4 of 12 Old 10-30-2012, 02:05 PM
ajmorell
ajmorell's Avatar
You drove it with the front trackbar disconnected? Don't ever do that again. The weight of the vehicle needs to be resting on the tires/ground when you turn the wheel or it won't work.
ajmorell is offline
post #5 of 12 Old 10-30-2012, 05:33 PM
RaggedOleMan
2" ratchet strap from axle to frame to locate the axle and set the trac-bar bolt. For example, axle/passenger to frame/driver. Cinch it up until it's where you need it. Adjustable trac-bar would be better so you can center the axle...
RaggedOleMan is offline
post #6 of 12 Old 10-30-2012, 07:58 PM Thread Starter
edgonzo11
Can you dummy it down? Lol
post #7 of 12 Old 10-30-2012, 09:41 PM
RaggedOleMan
Put one end of the ratchet strap on the frame on the drivers side, attach the other end to the axle, like on the back side of the inner "C", start ratcheting it. It will pull the axle towards the drivers side, and as it does you watch to see when the axle side trac-bar bolt slips through. Might be easier if you have some help, but not completely necessary, if you set the ratchet up so that you're ratcheting from a location where you can watch the holes line up.
You could also use a come-along, but the 2" ratchet strap is much easier. A 1" ratchet strap may not be strong enough, I use a 2" when I do it. Good luck, you'll get it.
post #8 of 12 Old 10-31-2012, 12:00 AM Thread Starter
edgonzo11
Thanks a lot man. So this means I will not need to buy an adjustable trac-bar or a bracket right?
post #9 of 12 Old 10-31-2012, 03:00 AM
RaggedOleMan
Do you "have" to buy an adjustable trac-bar to get the bolt to line up? Nope. That said, you just lifted your rig, so an adjustable trac-bar is a good thing if you want to center your axle.
post #10 of 12 Old 10-31-2012, 06:24 AM Thread Starter
edgonzo11
Yeah it's just for now until I could actually buy one
post #11 of 12 Old 10-31-2012, 12:07 PM
RaggedOleMan
By the way, welcome to Jeep Forum...
post #12 of 12 Old 10-31-2012, 12:43 PM Thread Starter
edgonzo11
Thanks a lot guys. I fixed it so Its all good
