trac lok on dana 44 - JeepForum.com
post #1 of 10 Old 10-28-2012, 05:59 PM Thread Starter
Tmblack3
trac lok on dana 44
so im looking for a limited slip for my factory rear open diff dana 44 w/ 3.73 now that i put the aussie in the front dana 30. im on a budget and this is my only vehicle so i need driveability as well as low price (less than $300 preferably). i know trac lok is clutch driven and tru trac/lok is gear driven. is the tru trac/lok an actuated differential or is it always on limited slip like the trac lok? people say the gear driven is better ive found some trac lok diffs that are used and i would replace the clutch plates on it. i did the aussie locker install in my dana 30 by myself with no problems, is there anything more difficult with installing a limited slip since you replace the carrier? do i need to shim/adjust the gears or anything or do i just drop it in?
04 TJ Sport- Kicker System, Smittybilt XRC-8 Winch, Cherry Bomb 18" Glasspack, 3" Zone Hydro Suspension Lift, 33x12.50 BFG KM2, 15x8 Procomp 7069, Aussie Locker front Dana 30, JKS 1.25" Body Lift, 4 100w Hella 500s
Tmblack3 is offline
post #2 of 10 Old 10-28-2012, 06:11 PM
BlueRubiconrich
I would look for Dana 44 powerloc it's a better L/S then a tracloc
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #3 of 10 Old 10-28-2012, 06:17 PM Thread Starter
Tmblack3
Ok whats the difference/advantages?
Tmblack3 is offline
post #4 of 10 Old 10-28-2012, 06:28 PM
BlueRubiconrich
the differance is a powerloc has 4 side gears a trac loc has 2 powerloc is stronger and better offroad.
post #5 of 10 Old 10-28-2012, 06:36 PM Thread Starter
Tmblack3
Ok so how does a powerlok work?
Tmblack3 is offline
post #6 of 10 Old 10-28-2012, 06:41 PM
BlueRubiconrich
a powerloc is a HD limited slip not a light duty limited slip like the tracloc.
it has clutchs like a tracloc but lasts longer.
post #7 of 10 Old 10-28-2012, 07:21 PM Thread Starter
Tmblack3
Ok so if i found a power or trac lok that fit my 3.73 gear ratio, is it easy to replace the clutch components and is it just a drop in install for the carrier?
Tmblack3 is offline
post #8 of 10 Old 10-29-2012, 05:50 PM
BlueRubiconrich
no you have to set it up like a ring and pinion. googlr randys ring and pinion
I think that's the site I know it's Randys
post #9 of 10 Old 10-29-2012, 06:19 PM
rjbruzan
I have had all 3 in different rigs. I would try for a TrueTrac as it is vastly better.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #10 of 10 Old 10-31-2012, 07:45 PM
BlueRubiconrich
oh I forgot about the truetrac yes no clutches but could be hard to find used.
still would have to set out the gears.
