TPS Throttle Position Sensor Problem - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > TPS Throttle Position Sensor Problem
Warn and Smittybilt Free Shipping OfferNew items recently added to Oconee Offroad15 x 8 Black D-Window Steel Wheels Set of 4
Unread 12-19-2004, 02:38 PM   #1
shaliburton
Engine light has been coming on and off so ran the codes at the Jeep dealer and Autozone. Determined that TPS sensor needed replacing. Problem is I can't find one for my 2002 Sport 6 cyl. Anyone have any ideas? Will probably try the Jeep dealer parts dept tomorrow but to install it they wanted $150. Sensor alone should be much cheaper. Any ideas on the cost?
shaliburton is offline   Reply With Quote
Unread 12-21-2004, 09:40 AM   #2
BamaJeeper
Call your local parts stores for the part number for an 02, 00, 97, and 95 TPS.
I would think the part #'s would be the same in those years and it's easy to swap it yourself. You may also need a T-20 tamper-proof torx bit ($3@ autozone) to remove the sensor. It's a torx bolt with the damned raised center.
Out of the darkness comes light.
BamaJeeper is offline   Reply With Quote
Unread 12-21-2004, 09:43 AM   #3
robbieaoa
1987 FSJ Wagoneer
Have you tried Napa? That's were I got mine.
Rob
[CENTER]Stock or [I]Overclock[/I]?
Drive it like ya stole it.
Fold um if ya got um.
If it says 4x4 on the side, get it dirty.[/CENTER]
robbieaoa is offline   Reply With Quote
Unread 12-22-2004, 02:22 PM   #4
Brian's 97 ZJ
Shaliburton,
As a cautionary note, the bolts that hold the TPS to the throttle body are steel and the throttle body is aluminum. Unless the bolts had a bitumus coating applied to them before they were installed, it is possible for the bolts and throttle body to fuse together. I found this to be the case for me when I needed to replace my TPS. In the end I twisted the heads off the torx bolts to get the TPS off. With firm grip on the shaft (yeah, that's right ) with Vice GripsŪ I managed to remove one but broke the other off flush with the throttle body. I ended up drilling out the broken bolt and putting a helicoil in.
- Brian
For some reason, being a member of the CharGold Jeep Club just isn't as cool... Member #1
Brian's 97 ZJ is offline   Reply With Quote
Unread 12-24-2004, 03:29 AM   #5
BamaJeeper
Damned that Michigan weather.
Unread 12-24-2004, 10:08 AM   #6
JSBlu974X4
150 HA. it took me like 10 minutes to put mine on. got mine at the local advance auto
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline   Reply With Quote
