Tom Wood driveshafts? - JeepForum.com
post #1 of 2 Old 05-03-2012, 09:53 PM Thread Starter
GWoods
I purchased a Woody replacement shaft for my TJ a few years back after installing a SYE. Since then I am now on my second rear joint. This last change I was almost unable to remove the shaft from the rear pinion yoke. The shaft would not collapse without the use of a large pry bar. After removing the rear joint and the rubber boot on the shafts slip spline, I had to use the hydraulic shop press to separate the shaft. Even after cleaning and lubricating both halves really well I could not reassemble the two without the aid of the press.
I eventually stripped off the blue Teflon(?) coating from the splines. Which now allows the shaft to expand and compress.
Just wondering if anyone else has had a similar experience?
GWoods is offline
post #2 of 2 Old 05-04-2012, 10:14 AM
biffgnar
biffgnar's Avatar
Is your rear pinion properly oriented?
Have you called and talked to TW about it? They have excellent customer service.
Romney in 2020!
biffgnar is online now
