TJ rough idle, need some help! - JeepForum.com
post #1 of 7 Old 06-28-2013, 08:41 PM Thread Starter
arnoldosu1
I have in the past couple months been having issues upon starting my tj. It starts fine every time: It's only once I start that I have rough idling. If I'm pressing on the accelerator it doesn't seem to be an issue. Also once I start driving it, the engine starts to cut out almost, in which case I have to depress the clutch and rev the engine some. Once I start driving it really isn't an issue anymore except on occasion when at a complete stop...or if I turn off the car for even like 10 min or so. And now recently my car appears to be leaking oil, but I have not added any oil as it appears to have plenty in the tank also I have plenty of oil pressure...I do have a little over the recommended full line btw and pressure is over half on the gauge.
I have seen similar things on this forum but nothing exact that had been resolved, so I apologize if there is a thread with this exact issue and the solution. Thanks, I just joined today in hopes that someone on here could help!
arnoldosu1 is offline
post #2 of 7 Old 06-29-2013, 05:25 PM Thread Starter
arnoldosu1
Anyone? No wires/cables, feel/look loose in the engine compartment...Is there anyone who knows what this could be? I'm about to have to take it to a repair shop...it is my daily driver and I can't just start guessing what the issue may be. Thanks in advance.
post #3 of 7 Old 06-29-2013, 09:35 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Miles? Tune up last done? Any codes? Need a little more info.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #4 of 7 Old 06-30-2013, 06:38 PM Thread Starter
arnoldosu1
It has 95,xxx miles on it. I changed my oil 94,xxx with royal purple and k&n oil filter. I changed the spark plugs and wires with performance plugs and wires 25,000 miles ago I think (can't remember what brands but they are both very nice; no miss fires). Also no codes, which is why I am puzzled haha. I was thinking it must be some kind of sensor because it runs well when it isn't acting up. But it also leaks a little oil. Any ideas...hopefully thats a good amount of information. thanks!
post #5 of 7 Old 07-01-2013, 01:20 PM Thread Starter
arnoldosu1
Well I'm still unsure what it is...but I am going to run fuel injector cleaner (lucas) to see if maybe that could solve it. I have never used fuel injector cleaner with this car for the 45,000ish miles I've put on it. Maybe it will be that simple. Though I still don't get the oil leaking part of it...incase anyone cares I will post back on here what the result is.
post #6 of 7 Old 07-10-2013, 12:01 PM
bmxboy809
did you ever figure it out? I am having the same surging/idle/misfire problem on my TJ. No oil leak for me tho
1999 Wrangler TJ 4.0 5spd -- 6" LA , 35" MTZ's , Ford 8.8 , 4.88 gears , SYE , Tom woods CV shaft
bmxboy809 is offline
post #7 of 7 Old 09-03-2013, 02:49 PM Thread Starter
arnoldosu1
I have not figured it out. The fuel injector cleaner did nothing for me. I have been meaning to get it back to my mechanic to see what else it could be...I'm thinking some sort of sensor (throttle position sensor, idle control, or something)...because all I have to do is rev the engine several times and it begins to run properly; though sometimes better than others.
Also sorry for not responding for so long, I didn't get much of a response on here to begin with and I never received any email notification or anything from your response. Have you maybe found a solution to your problem?
2.5 liter , help needed , oil , rough idle , wrangler
