-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   TJ Ignition problems (http://www.jeepforum.com/forum/f19/tj-ignition-problems-1372608/)
TylerCarter 05-23-2012 07:10 PM
My 97 TJ's ignition has locked up. It will not turn over at all. It will turn far enough for the radio and everything to come on, but after that it just feels locked up. Any ideas on what the problem is?
jnicewan 05-23-2012 10:05 PM
Check the key first, make sure its not bent, also try another key if you got one. Try spraying some penetrate/lube into the lock cylinder and if that doesn't work then use a small hammer and lightly tap the end of the key or cylinder as you try to turn it.
I cant remember exactly but you might be able to remove the lock cylinder and ignition switch as a unit and then it might be easier to try to seperate the two. If you can get the key turned to the "ON" position there is a small hole at the bottom of the plastic column shroud (under the cylinder) stick a small screwdriver in the hole and push the button up and remove the cylinder. With cylinder removed you should probably be able to figure out which one might be the problem.
The time now is 03:45 AM.
