Tj dana 30 axle question - JeepForum.com
post #1 of 4 Old 10-15-2013, 11:39 AM Thread Starter
jpin86
I am going from 3.07 gears to 3.73's (Daily driver going to run 31's), 2003 TJ. I got a dana 35 with a super 35 kit ready to install. I found a 1997 dana 30 front with 3.73's. It looks like the calipers and pads are the same between the 1997 and 2003 dana 30, but the hub bearings and rotors are different. Does anyone know if I can put my 2003 hub bearings and rotors on the 1997 axle and bolt it in?
jpin86 is offline
post #2 of 4 Old 10-15-2013, 11:42 AM
purplepig
You might need your knuckles. I just put a HP out of a 95 XJ in and I was able to use my stuff with my knuckles.
purplepig is offline
post #3 of 4 Old 10-15-2013, 11:45 AM
biffgnar
biffgnar's Avatar
As long as you swap the unit bearings and rotors you should be fine. Everything else is the same.
biffgnar is online now
post #4 of 4 Old 10-15-2013, 11:58 AM Thread Starter
jpin86
Cool, thanks guys.
jpin86 is offline
