TJ Clutch Creak,Squeak,Nosie Galore *VIDEO* - JeepForum.com
post #1 of 15 Old 02-10-2009, 06:37 PM Thread Starter
peeweeXJ
I love my 2002 TJ, but the clutch is making some pretty annoying sounds. I can feel it in the pedal too.
I am a mechanic, but maybe I've been layed off for too long?
I have this noise (SEE VIDEO) that occurs when I depress the clutch.
I pulled the slave cylinder, and the piston is good to go. The nylon cap on the end of the rod looks real good too. I lubed it up just in case.
I power washed my Jeep the other day, and sprayed up under the inspection cover. The clutch pedal smoothed up, and wasn't making noises for 50 miles or so.
Now it's back. Very annoying. I can feel a rough spot in the pedal as I depress it, and can hear the noise from inside the Jeep.
The problem is NOT in the pedal, or hydraulic system.
Not sure if I really want to wash it thoroughly, as I might spray some of that rear main leakage onto the friction surfaces.
Thanks
peeweeXJ is offline
post #2 of 15 Old 02-12-2009, 10:48 AM Thread Starter
peeweeXJ
Thanks for the help. Haha.
I got it fixed yesterday.
I stole this picture off of Jeeps Unlimited.
The squeak was not coming from where the slave cylinder pushes on (right side).
The noise comes from the pivot stud on the left side. There is a spring that holds the lever tight against the stud. When the spring flexes it creaks and makes other horrible noises.
To fix this. I removed the starter and the slave cylinder. From the slave cylinder side I pulled on the release arm. This popped the spring off and revealed the pivot stud.
Through the starter hole, I sprayed the stud with white lithium grease real good.
Reinstalled and no noises.
peeweeXJ is offline
post #3 of 15 Old 04-04-2010, 01:22 AM
takao
Peewee xj thank you for the information that noise is driving me crazy I will try this solution. I have the same noise as yours did. you also stated that a spring popped off when you:
"This popped the spring off and revealed the pivot stud."
was it difficult to put the spring back on...
thank you...
takao is offline
post #4 of 15 Old 04-04-2010, 12:47 PM Thread Starter
peeweeXJ
The spring is the main problem. You will want to remove it completely.
The spring is there mostly for the assembly part of the Jeep. It holds the lever in place when the slave cylinder is removed.
When the slave cylinder is installed, there is pressure on the bar, so the spring is not needed.
Good luck.
peeweeXJ is offline
post #5 of 15 Old 04-04-2010, 02:45 PM
Imped
Imped's Avatar
AWESOME!. I've got the same annoying sound. I'll do that today.
OlllllllO
IndyORV
Imped is offline
post #6 of 15 Old 08-09-2010, 03:03 PM
JimTJ
Sorry for bringing this one back from the dead.
I have a couple questions if anyone who reads would be so obliged to help me out.
Is the picture up there of the transmission still mounted in the Jeep?
and
When you unbolt the cover, is there any fluid in there with all of that or is it bare like in the picture?
My clutch pedal just started doing this so I'd like to take care of it.
Any help would be fantastic!
James
JimTJ is offline
post #7 of 15 Old 08-09-2010, 05:39 PM Thread Starter
peeweeXJ
The picture shows the transmission pulled away from the rear of the engine.
There will be no fluid in there. In the picture, that particular Jeep had a leaking rear main seal on the engine.
There is no cover to remove. Remove the starter and slave cylinder, and use a flashlight to look into the housing.
Good luck.
peeweeXJ is offline
post #8 of 15 Old 08-22-2010, 12:40 PM
JimTJ
So, this is still an issue with my Jeep and now its REALLY annoying.
So to put this in layman's terms:
I unbolt the slave cylinder
Unbolt the starter (?) (Where is the starter?)
Pull on the release arm through the slave cylinder
And the spring pops off?
then shoot it with grease
Does this sound right?
James
JimTJ is offline
post #9 of 15 Old 08-22-2010, 04:18 PM Thread Starter
peeweeXJ
That's a big 10-4!
Starter is opposite side of slave.
Pm sent...
peeweeXJ is offline
post #10 of 15 Old 08-22-2010, 07:10 PM
JimTJ
Peewee your inbox is full.
James
JimTJ is offline
post #11 of 15 Old 03-04-2011, 08:31 AM
uf20wop
bumping this thread from the dead
but i have this problem now
so is the solution to remove the spring completely and spray some lube on the stud?
uf20wop is offline
post #12 of 15 Old 03-17-2011, 11:03 AM Thread Starter
peeweeXJ
Correct!
peeweeXJ is offline
post #13 of 15 Old 10-11-2012, 09:59 PM
keller_k5
PeeWee, I sent you a PM, but got it figured out tonight. I followed your write up and was able to get to the spring through the starter hole. All I can say is thanks. That noise drove me crazy. It sounded like an old car door whenever I shifted. Now I have absolutely no noise whatsoever and the clutch is super smooth. I do not feel anything in the peddle either as I did before. Thanks again for the info.
keller_k5 is offline
post #14 of 15 Old 07-23-2013, 02:03 PM
-sean-
-sean-'s Avatar
1944 CJ2
Worked like a charm, that clicking was SO annoying!
-sean- is offline
post #15 of 15 Old 01-04-2017, 04:55 PM
Blairh009
Sorry to revive such a old post. Hope someone will respond. I'm having the same issue. I removed the slave from the trans but from there I need a more in depth how to please. Why do have to remove the started and where is the arm and spring ? Inside the trans?
Blairh009 is offline
Squishy clutch then the clutch just locked up completely is it the master, slave or ? GPII Engines & Drivetrain 1 11-25-2011 08:36 PM
Front driveline squeak. Not sure what causing it Carolinatj906 Engines & Drivetrain 3 01-11-2010 07:28 AM
nosie when driving my xj. ZeroCool8891 Engines & Drivetrain 1 12-13-2009 09:51 PM
Hell Creak Suspension....?? got_4_lo General Jeep & Off-Road Equipment 3 12-16-2005 01:22 PM
