A Tip About Rich Porter Technology Cam Shaft Synchronizer Installation - JeepForum.com
post #1 of 1 Old 06-03-2012, 04:12 PM Thread Starter
Tracy1974
My old oem camshaft synchronizer had play in it and just couldn't seem to get it in perfect time so I bought a Rich Porter Technology also known as RPT. The new synchronizer came with an alignment cap that when installed completely had the unit in a totally different position as the factory one. And as they failed to include instructions to explain this I went ahead and installed it anyway. Keep in mind the slotted alignment cap will only go on one way. And as I figured it would not start and backfired right away. So I took the cap off and compared the two side by side with oem in sync with pin in the two holes and adjusted the RPT to the same position and installed. By the way the oil pump slot now had to be in the 1:00 position instead of 11:00 position. Installed and fired right up. So if anyone buys one and runs into this senario this is how I solved it.
Tracy1974 is offline
