Timing issue? - JeepForum.com
post #1 of 1 Old 01-25-2009, 12:24 PM Thread Starter
Squirrely
1948 CJ2A
Timing issue?
I have a 48 that someone stuffed a 260 V8 into. I just replaced the points with an electronic system. The timing was way out, so I tweaked it a little untill I got the idle smooth.
There are a couple problems.
I have timing marks on the balancer, but not on the block... so I don't know what to do to properly time my engine. Suggestions?
The engine idles smooth, and when in neutral it runs great and revs perfectly. But put the rig in gear and the engine struggles to run. It sputters and seems bogged down untill the rpm gets up to 2500 then it goes like hell. It used to backfire thru the exhaust but my timing tweak seems to have fixed this. What gives with the lack of power under load?
I put a rebuilt motorcraft 2100 on with stock jets and air fuel mix 2.5 turns out. Intake manifold is from a 302, block is a 260. Replaced fuel lines and filters, new plugs, cap, wires, roter, rewired intire engine, gas is a couple months old.
Squirrely is offline
Ground Issue/Dash array issue CARVAL Audio, CB & Ham Radios, GPS, & Electrical 3 12-23-2009 10:49 PM
4.2 4.0 timing issue? triz250mn Engines & Drivetrain 2 04-16-2009 07:33 PM
4.0 cam crank timing issue meucci Engines & Drivetrain 0 03-03-2009 11:07 PM
weird issue with tbi timing on 304 BigDumbBear General Jeep & Off-Road Equipment 0 02-18-2009 01:21 PM
Help - calling all flywheel and bellhousing gurus for a motor swap timing issue. jwicker Engines & Drivetrain 21 02-17-2006 07:17 AM
