Timing issue? - JeepForum.com
post #1 of 4 Old 10-23-2013, 12:20 PM Thread Starter
Cherokee71
Timing issue?
I have a 2000 Cherokee with a 4.0 that won't run. Sometimes it acts like the timing is too advanced, sometimes too far retarded, and sometimes it fires up fine but dies after a few minutes. I've replaced the camshaft position sensor, crankshaft position sensor, ECM and timing chain all to no avail. The MAP sensor tests good. Any ideas?
Cherokee71 is offline
post #2 of 4 Old 10-23-2013, 03:18 PM
uberxj92
1992 XJ Cherokee
Make sure all of the ground wires are good and tight.
Check your fuel pressure.
Clean the throttle body out.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 4 Old 10-24-2013, 07:04 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Does you CEL light up? If not, then throwing sensors at the problem is a waste of money.
Remove the Idle Air Control sensor from the throttle body. Clean it with carb cleaner and 0000 steel wool. Clean out the bore it sits in also.
See what that does.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is online now
post #4 of 4 Old 10-24-2013, 07:15 PM Thread Starter
Cherokee71
Yes, it's thrown codes for everything I've replaced, but its done no good.
