#1 | |
Timing chain woes
Here's my problem. I'm trying to install Compcams True Roller Timing chain set on my 1987 258. While I'm fitting the chain cover on the block, the cam bolt is hitting the cover (clearance, who would have thought). That's probably why Compcams makes this chain set for 75'-86' only. However, are these blocks not totally the same? COMP can't tell me why they discontinued this set after 86'. So, I was wondering if anyone knew if this chain set is actually compatible with my application. Can I simply find a smaller washer or bolt to reduce clearance? Or am I looking at a bigger problem in timing differences. Are the crank keys in different positions between these years? I would really like to use this roller chain, so any HELP please!!!
#2 |
I think you guessed right that that is probably the reason for the '75-'86 designation. It sounds like maybe the timing cover is what is different. Maybe you could find a timing cover off of an earlier model. This is completely speculation, I have no idea if it will work or not.
I would think that as long as the timing gears are the same size and tooth count that it would work with your application. My $0.02. Like I said earlier, I don't know if any of this will work or not. These are just some things that I would try.
'85 CJ7 258 w/Weber Carb and Nutter Bypass. Dana 44's F&R, 3.73 gears with Trac-Loc rear. Always looking for peoples $0.02. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
