Quantcast timing chain noise?? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > timing chain noise??
Old 05-05-2007, 08:28 PM   #1
cherojeep
Well I had my jeep looked at and was told i have a rod knock first. got a guy i know to give me his opinion and he seems to think its timing chain. he did the old stethescope diagnosis with a screwdriver all over the motor and heard nothing from the oil pain area but heard it right behind the crank pulley where the chain is on the crank.
is it known for timing chains and/or tensioners to go bad?? he also seems to thinnk the heads were already off it at one time.
i dont want to tear it apart if its something major. so i would like some opinions
2004 Jeep Grand Cherokee Limited
2005 Acura TSX
2007 Kawasaki ZX6R
cherojeep is offline   Reply With Quote
Old 05-06-2007, 08:53 PM   #2
jeepdaddy2000
1971 CJ5
Try rotating the crank back and forth while observing the rotor. I believe 10 degrees is acceptable slop. Anything over that and you are looking at a replacement.
jeepdaddy2000 is offline   Reply With Quote
Old 05-07-2007, 06:35 PM   #3
cherojeep
replacement what?? chain/tensioner??? engine?? rotor as is distributor?
2005 Acura TSX
2007 Kawasaki ZX6R
Old 05-08-2007, 05:57 AM   #4
jeepdaddy2000
1971 CJ5
Yes..no...yes
Old 05-08-2007, 08:26 AM   #5
75SV1
The timing chain isn't a major project. Basicllay a bit more involved than a water pump. Beyond a water pump, you will have to take off the front cover. The timing chains do streach.
Tom
75SV1 is offline   Reply With Quote
Old 05-08-2007, 04:34 PM   #6
cherojeep
hmm guess if i dont sell it i will fix it.
2005 Acura TSX
2007 Kawasaki ZX6R
Old 05-09-2007, 03:42 PM   #7
Heepajeep
if it is a rod knock at idle, it will go away or be noticeably less knock when the offending cylinders spark plug wire is pulled off.
Heepajeep is offline   Reply With Quote
Old 05-10-2007, 10:53 PM   #8
cherojeep
oil pressure is low. idle it reads 0ish and cruising is about 40. what suggests can you give?
2005 Acura TSX
2007 Kawasaki ZX6R
Old 05-11-2007, 05:46 AM   #9
75SV1
First I suggest you have the oil pressure measured by a manual gauge. Make sure the dash gauge is reading correctly. Then if its reading that low, I would think its time for a new oil pump.
Tom
Old 05-17-2007, 06:20 PM   #10
cherojeep
see what happens, my master tech buddy is leaving the dealership i work for and hes the only guy i trust 100%
2005 Acura TSX
2007 Kawasaki ZX6R
Old 08-08-2010, 05:08 PM   #11
Apollo21
bump for solution
Patrick- MIDN 2/C USMS (USN)
Skipper of [I]SIRINA[/I] 1969 31' Bertram
2002 Red Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, sweet headlights, rear addco, spring retainers, KOR SS, liftgate light, Alpine/Polk speakers, and power inverter with USB.
Build thread [url]http://www.jeepforum.com/forum/f22/apollo21-build-thread-902929/[/url]
[QUOTE=Jerry Bransford;11691320]Worrying too much about mpg with a Jeep is similar to worrying about your sister's virginity. An ok thing to be concerned about but...[/QUOTE]
Apollo21 is offline   Reply With Quote
Glock Forum
