timing chain keeps breaking - JeepForum.com
post #1 of 4 Old 08-12-2007, 06:05 AM Thread Starter
tugboat
1982 CJ7
we rebuilt a 1981 258 ci engine and put in a comp cams cam kit [ cam,timing chain set,lifters]. After 2400 miles the timing broke and the teeth broke off on the lower gear. we sent it back to comp cam and the sent a new cam, lifters and timing set.we insalled it and broke in the cam.Then after starting it a second time and reving it up a little the chain and gear broke again.I don't know what breaks first the gear or the chain but it puts a hole in the side of the timing cover each time. Anybody have any ideas why this would be happening? comp cams has no idea
Steve
tugboat is offline
post #2 of 4 Old 08-12-2007, 10:50 AM
cjjeeper258
That is a weird problem. A chain that is on a slight bind could over time fatigue and break. Perhaps there is an issue with the crank nose. Check for burs or apparent damage especially where the face of the gear contacts the crank.
Perhaps you have excessive run out on the crank and it is moving around and causing your problem.
cjjeeper258 is offline
post #3 of 4 Old 08-13-2007, 04:33 AM Thread Starter
tugboat
1982 CJ7
the engine was just rebuilt everything is new.Is anyone else using a timing set from comp cam? i'm thinking of trying a different brand
steve
tugboat is offline
post #4 of 4 Old 08-18-2007, 08:27 PM
Nonya
how tight is the chain when its installed new?
Nonya is offline
timing chain noise?? cherojeep Engines & Drivetrain 13 03-11-2014 07:02 AM
timing chain replacment on 4.7 jyachera Engines & Drivetrain 3 03-10-2011 01:46 PM
timing chain and sprocket? 77mudder Engines & Drivetrain 4 10-09-2002 07:57 PM
Timing chain replacement CJ8DV8 Engines & Drivetrain 2 07-30-2002 10:45 AM
Timing Chain Question holmes133 Engines & Drivetrain 0 02-22-2002 10:23 PM
