time for and oil chage or not?? - JeepForum.com
post #1 of 3 Old 07-10-2005, 05:06 PM Thread Starter
arieljeep
Hi, my 98XJ has as of now 121643m on it, 3 months have past from my las oil change, but i did not get 3000m out of it, on 122958m it will be 3000m from the last oil change, i use 10W-40 Synthetic Blend form Quaker State and i add a can of RESTORE to it, the oil filter that i use is K&N, the thing is should i change the oil or not and wait some more time??
arieljeep is offline
post #2 of 3 Old 07-12-2005, 05:30 PM
Rock1127
Every 3000 miles is not a set-in-stone rule. It's "about" every 3000 miles. If you change it at 2500 or 3500 nothing will happen. Also, when talking about "every 3000 miles or every 3 months", it's generally whichever comes first. So if you go 3 months and have only driven 1000 miles, it's probably not as important as if you were to go 3000 miles in one month and wait 3 months.
It's all a personal thing...
Rock1127 is offline
post #3 of 3 Old 07-12-2005, 06:10 PM
meat12
meat12's Avatar
If you are using syn you can go more than 3k if you want. I use a semi-syn and change every 3k but thats just me. There was a thread on here where guys were going much longer between changes. It sounds like a pretty expensive oil change, so I would let go a little longer if you are comfortable doing so.
91XJ- NP231, 31x10.5 MTR's, 15x8 soft 8's, BB, K&N intake, Cherry bomb exaust, CB, Stereo mods, fog lights, custom Aluminum body work to cover rust.
Rember: If they dont find you handsome, at least they will find you handy!
meat12 is offline
4wd part-time and full-time question flyboy14295 Engines & Drivetrain 2 01-29-2009 03:22 AM
Full Time 4X4 to Part Time 4X4? Roudy4x494 Engines & Drivetrain 1 06-30-2008 04:14 PM
Full-Time 4WD vs. Part-Time 4WD goose1 General Jeep & Off-Road Equipment 11 08-22-2007 08:54 AM
Full Time To Part Time CHAOTICMELTDOWN General Jeep & Off-Road Equipment 1 09-02-2005 11:41 AM
Time For New Tires, So It's Time For New Wheels and Bigger Tires...Need Suggestions A&BSport Tires & Wheels 16 11-11-2004 08:21 PM
