Throw out bearing failing...should it be covered under drivetrain warranty? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Throw out bearing failing...should it be covered under drivetrain warranty?
Steering Y-Link Adapter!Ruffstuff Axle Simple Swap Kit!Our Panhard / Trackbar brackets, Variations......
Unread 02-24-2015, 08:35 AM   #1
hunterw0026
Hi all,
I have a 2011 two door Wrangler sport that I purchased brand new in March of 2011. Appears from three different friend (not yet gone to mechanic) my throw out bearing is failing.
I want to be educated before I start taking it places and making calls as I do know if not covered this is a big and time consuming job.
This is something I found in my warranty: Transmission: transmission case and all internal
parts; torque converter; drive/flex plate; transmission
range switch; speed sensors; pressure
sensors; transmission control module; bell housing;
oil pan; seals and gaskets for listed components
only.
NOTE: MANUAL TRANSMISSION CLUTCH
PARTS ARE NOT COVERED AT ANY TIME.
Any thoughts that anyone can give me would be most helpful and VERY APPRECIATED as a single gal!!!
hunterw0026 is offline   Reply With Quote Quick reply to this message
Unread 02-24-2015, 09:06 AM   #2
mdm
Farm Wheeler
Throw out bearing is not covered by your warranty.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote Quick reply to this message
Unread 02-24-2015, 09:22 AM   #3
hunterw0026
Thank you! Any ideas on how much I will be looking at? I saw a few things online that say anywhere from $500 to $1200?
Unread 02-24-2015, 10:00 AM   #4
mdm
Farm Wheeler
If it is in fact the throw out bearing I'd recommend you replace the entire clutch while it is torn down; clutch plate, pressure plate, throw out bearing. The labor is by far the biggest part of the cost and I wouldn't want to pay the labor costs twice by not doing it all now and having the clutch go out later.
Cost? Haven't had anything done by a shop in many years. $1000 +/- for the whole clutch wouldn't surprise me.
$300 for the clutch kit - clutch, pressure plate, throw out bearing + $600-700 labor
$50 for the throw out bearing + $500-600 labor
Someone with more recent experience with having shop work done may be able to give you a better estimate.
