Throttle Linkage (Rochester Carb) - JeepForum.com
post #1 of 4 Old 05-14-2002, 07:56 PM Thread Starter
Zeke
Hey guys,
As Jeepdaddy2000 already knows, I'm installing a Rochester carb on my '87 Wrangler with the 258. My latest problem is the throttle linkage.
I built a triangular adaptor thing that bolted on to the carburetor on 2 corners and had the old ball joint on the third, but this made the acelerator cable stick when the gas pedal hit the floor (not if done slowly), and also only got the carb to about 1/2 throttle.
My question is how you all with Rochester carbs made throttle linkages. I've read about it, and people have said that its easy, just do a little fabbing but I'm struggling here.
Thanks!
Zeke is offline
post #2 of 4 Old 05-18-2002, 11:01 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
First the sticking cable.Is the cable crimped or out of alignment? Twisted? Disconnect the cable from the carb and pull it by hand. Does it feel smooth? Once you get the cable to pull smoothly you can look to the throw problem.
You said that you could only get about 1/2 throttle. Try pulling the cable housing back away from the mount. this should cause the pedal to rise giving added length to the throw. Another fix is to lower the cable attachment point on the carb. This will shorten the throw arc. Hope this helps.
bazinga
jeepdaddy2000 is offline
post #3 of 4 Old 05-19-2002, 06:45 PM Thread Starter
Zeke
Thanks for the help! I finally got my Jeep up and running with the Rochester, it turns out I just needed to move the balljoint closer towards the grille and fender (if that makes sense to you). I really like the Rochester, can't wait for it to rain so I can see if it works then. I haven't done the Nutter bypass yet either, so I guess I'll do that as soon as I have time.
The Rochester doesn't work with my stock air cleaner - its not high enough. I guess I could just buy some spacers, but I'm going to upgrade to a big chrome air filter assembly - only $50 from Summit.
Thanks to everybody who recommended the Rochester swap, it works great!
Zeke is offline
post #4 of 4 Old 05-19-2002, 11:23 PM
jeepdaddy2000
1971 CJ5
If you run in dusty conditions, stay with a stock snorkle style air filter housing. The open(chrome) style will suck dust and dirt all away around the filter causing you to have to change it more often.When the dirt comes down the snorkle, the mass of the dirt forces it into the filter in front of the snorkle, leaving the rest of the filter realitivly clean.You can also run a fresh air tube from the snorkle to the grill, pulling cold air instead of the heated air off the engine.
bazinga
Any carb guys? Rochester Quad on the Chevy 305 in my Jeep learfxr Engines & Drivetrain 5 08-12-2009 06:51 PM
Rochester 2GC 2bbl carb on GM 5.7L runs high rpms 3S00W Engines & Drivetrain 25 01-26-2009 05:16 PM
MC2100 Throttle linkage ScotZ Fabrication Shop 1 04-19-2006 01:37 PM
Anyone with a Rochester carb? Zeke Engines & Drivetrain 3 05-08-2002 09:52 PM
HEI Ignition and Rochester carb mods dpoliver Engines & Drivetrain 5 04-29-2002 05:06 PM
