THrottle Body Spacer - JeepForum.com
post #1 of 8 Old 05-22-2013, 06:35 AM Thread Starter
02black
Do throttle body spacers really work? Are they worth the money or is it better spent on a more free flowing exhaust?
02black is offline
post #2 of 8 Old 05-22-2013, 10:03 AM
Newtons3
No, they don't work, at least not as advertised. Your money is better spent on a free flowing exhaust.
Newtons3 is offline
post #3 of 8 Old 05-22-2013, 11:02 AM
mdm
Farm Wheeler
Of course they work. Their purpose is to remove money from your pocket and put it into the pockets of the people that make and sell them. They are very efficient at this.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #4 of 8 Old 05-22-2013, 05:49 PM
Spud100
Better idea. Put in a larger throttle body. I replaced my stock throttle body (52mm diameter neck) with a 60mm. I picked up huge power for a bolt on mod. I bought mine on ebay from a guy in Austin, tx. Who rebuilds and bores out throttle bodies to larger diameters. He recommends 60mm for the jeep 4 cylinder and 62mm for the 6 cylinder. Cost was $160 but well worth it.
Spud100 is offline
post #5 of 8 Old 05-22-2013, 06:09 PM
eduardostewart
can anyone back up the worthiness of one of these?
eduardostewart is offline
post #6 of 8 Old 05-22-2013, 06:52 PM
GilaMtnJeep
GilaMtnJeep's Avatar
There are countless studies and consumer reports on throttle body spacers. The only thing they are good for is making you part with your money.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #7 of 8 Old 05-22-2013, 09:48 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
www.strokedjeep.com. get a bored throttle body from him and be done with it.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #8 of 8 Old 05-22-2013, 09:52 PM
JasonMHorn
Don't waste your money on the spacer. Go with the 60MM TB instead. You will gain a little more power. Not a HUGE power increase. Just a little. I just did mine. I got it from a junkyard from a Cherokee with a straight 6 for $25. If you opt to do this just make sure that you get one with a MAP Sensor if your Jeep has one. The first one that I got was from an older Cherokee and it did NOT have the MAP Sensor. And second, when you install it make sure that you take notice of the tabs that are on the TB and intake manifold. If you put the TB on wrong, the tabs will touch and when you tighten it............CRACK!! And the TB is now trash. The one downside to this is that the opening in the intake manifold is smaller. So if you can, bore it out to match the TB. I didn't feel like taking the manifold off at the time so the air technically does bottle neck.
Here is a link from JP Mag about little things that you can do to get a little more power out of the 2.5 liter.
http://www.jpmagazine.com/techarticl..._power_adders/
JasonMHorn is offline
